TOS 7.0.1078 Beta (ARM) is Released for Update
Target Users:
Users currently running TOS 7.0.0500 beta or later versions.
Applicable Models:
F2-211, F2-212, F4-212
Note:
If your TOS version is prior to TOS 7, you can directly refer to the TOS 7 update method in this announcement.
Update Notes
Bug Fixes:
1. Fixed certain issues in File Managemer.
2. Fixed certain issues in Storage Managemer.
3. Fixed certain issues in App Center.
4. Fixed certain issues in Network Services.
5. Fixed certain issues in General Settings.
6. Fixed various other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.548 for Windows OS.
- MD5: 72701B52336AF9FD8B97A6BE9D5D5A7C
2. Download TNAS PC 5.2.548 for macOS (x86 architecture).
- MD5: BAA63A179C43F73965EA9C31EEB9D61E
3. Download TNAS PC 5.2.548 for macOS (ARM architecture).
- MD5: BB933DA867058884C4ADFE44EAD24AFC
4. Download TNAS PC 5.2.548 for Linux.
- MD5: 06FE93F9FFE47147854A34F28D57FCC2
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
Applicable Models:
Note:
Update Notes
Bug Fixes:
Update Procedure:
Client Downloads:
- crisisacting
- Silver Member
Re: TOS 7.0.1078 Beta (ARM) is Released for Update
Would/Could any of these be returning to future TOS 7 ARM builds?Surveillance Manager, iSCSI Manager, Portainer, Docker Manager, ZenTao, Verysync, or development tool
Unfortunately, for a number of reasons, the apps you mentioned are no longer available — and that includes any future ARM versions. Things might evolve later on, but for now and the foreseeable future, it's not going to happen.crisisacting wrote: ↑23 Jul 2026, 01:17Would/Could any of these be returning to future TOS 7 ARM builds?Surveillance Manager, iSCSI Manager, Portainer, Docker Manager, ZenTao, Verysync, or development tool
Does TOS 7 for armv8 support apps for TOS 5.1, created by community, e.g. jellyfin?
There are differences in the app specifications for the new version, so it may not work as expected. We recommend waiting for update from the community app developers.
- sianderson
- Silver Member
i still live in hope that the F2-210 will suddenly appear on an update list lol
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
May you grow old gracefully
Frustrated Beta Tester!!!
- sianderson
- Silver Member
you cant blame me for living in hope
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Philosophy 101: If it were ronseal, would this forum need to exist?
- sianderson
- Silver Member
i would so that people knew there was an update
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
