TOS7 Migrate system to another disk in TRAID
Pe6yc
Post by Pe6yc »
I noticed that the system in my TRAID array is only on the first drive. In TOS6, the system was cloned across all drives in the array to prevent the failure of any drive in the array from rendering the system unbootable. Is there a way in TOS7 to copy system files to other drives in the array to ensure bootability in the event of a system drive failure?
F5-422 (MAPL0304V22) - TOS 7.0.1536 (x86)
D8 Hybrid
Re: TOS7 Migrate system to another disk in TRAID
In Tos5 the default (and only) option was to have the system drive on all drives. That changed in the development of Tos6. There is a way to duplicate the system drive across 2 drives, but that is the limit.
viewtopic.php?p=59398#p59398
There are caveats noted in the Help files for this procedure.
Frustrated Beta Tester!!!
Pe6yc
Post by Pe6yc »
Gremlin wrote: ↑20 Sep 2026, 23:54There is a way to duplicate the system drive across 2 drives, but that is the limit
Add system disk button suggest to select more then one disk to add system files.
UPD: It is allowed to select one disk only, you are right.
Gremlin wrote: ↑20 Sep 2026, 23:54viewtopic.php?p=59398#p59398
Thanks for a link
D8 Hybrid
