[Help] Rsync not working
Rsync is a backup tool common to most Linux servers and clients.
IvIv
Cambodia
Post by IvIv »
Hi everybody,
I'm trying to back up my data from a TNAS to a Synology NAS using rsync. A user named “RSYNC” has been created on the destination system. The rsync service is enabled, and the SSH port is configured accordingly. However, after the first step, the Backup Wizard displays an error message stating that a connection could not be established.
In the terminal, however, both the connection and the file transfer work:
rsync -a -e ‘ssh -p xxxxx’ /Volume1/backup_test/test.txt [email protected]:/Volume1/backup_test/test.txt
I am using the latest version, TOS 7.0.0804.
Thanks for your help.
Re: [Help] Rsync not working
FYI you are a couple of versions behind.
rfbjr
Post by rfbjr »
Firewall? Both using the same rsync ports?
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
Are there any error messages in the Rsync logs? When creating the backup task, did you select SSH as the encryption method for transfer?
You can also try updating TOS to 7.0.1105 and then connecting again: viewtopic.php?t=10416
Return to “Rsync”
