TOS 7.0.0804 (x86) Official Release Update
Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Important: This update is only applicable to TOS 7.0.0746 and newer. Users with older versions must first upgrade to 7.0.0746 before applying this update.
Here, we sincerely thank @crisisacting, @snapsh0t, @greentower, @User009, @Gremlin, @ambul, @rfbjr, @weerasak, @Nitrokalel, @Grigorio, @Konstantin, @major65, @zeratyx, @plexjellyfin, @storageninja, @editsmith, @petrose and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Warning:
If your USB drive or disk is in NTFS format, please postpone the system update and wait until next Wednesday. If you are using the real-time monitoring feature in Emby, Plex, or Jellyfin, please manually perform a "Scan Media Files" from within the application after a system update. This will remove the "do not monitor" configuration lock that may have been left in place, ensuring that automatic scanning functionality is restored properly.
Update Notes
Bug Fixes:
1. Fixed the issue where the resource dashboard time was inconsistent with the system time.
2. Fixed the issue where viewing user group permissions would clear the group's permissions when the user group ID matched the user ID.
3. Fixed the issue where users with a purely numeric username would receive a permission denied error when logging in.
4. Fixed the issue where icons did not adapt to the number of files when viewing files in paginated mode.
5. Fixed the issue where deleting a large number of small files was too slow.
6. Fixed the issue where Plex, Emby, and Jellyfin could not scan media folders in real time.
7. Fixed the issue where Openclaw application installation might fail in certain cases.
8. Fixed various other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.548 for Windows OS.
- MD5: 72701B52336AF9FD8B97A6BE9D5D5A7C
2. Download TNAS PC 5.2.548 for macOS (x86 architecture).
- MD5: BAA63A179C43F73965EA9C31EEB9D61E
3. Download TNAS PC 5.2.548 for macOS (ARM architecture).
- MD5: BB933DA867058884C4ADFE44EAD24AFC
4. Download TNAS PC 5.2.548 for Linux.
- MD5: 06FE93F9FFE47147854A34F28D57FCC2
5. TNAS mobile for Android: Please search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
rfbjr
Re: TOS 7.0.0804 Official Release (x86) is Released for Update
Post by rfbjr »
All three devices updated w/o issue.
Bug Fix #1 looks fixed to me. 👍
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
nitzer71
Australia
Post by nitzer71 »
I upgraded to TOS 7.0.0804 specifically because the release notes state:
"Fixed the issue where Plex, Emby, and Jellyfin could not scan media folders in real time."
Unfortunately, after testing, I can confirm the issue still exists on my system.
My observations:
  • Plex and Jellyfin were installed from the TerraMaster App Center.
  • Manual library scans work correctly.
  • Scheduled scans work correctly.
  • Real-time detection of newly added media still does not work.
  • Library monitoring is enabled in both Plex and Jellyfin.
  • Folder permissions have already been verified.
Can other users who are running TOS 7.0.0804 and using the App Center versions of Plex or Jellyfin confirm whether real-time media detection is working for them?
I'm particularly interested in hearing from users who upgraded from TOS 6 to TOS 7.
I would also kindly ask TerraMaster to update the Plex and Jellyfin applications in the App Center to the latest versions, as this may be required for full compatibility with TOS 7.
Additional observation regarding Jellyfin App Center status:
Since an earlier TOS 7 version, I have noticed that clicking the Jellyfin desktop shortcut sometimes opens the App Center first, where Jellyfin is shown as "Not enabled". If I click the Jellyfin shortcut again, Jellyfin opens normally and reports that it is enabled. After returning to the App Center, the status then changes to "Enabled".
This appears to be a status synchronisation issue between TOS and the App Center.
F4-425 Plus | 16GB RAM | Intel(R) N150 | 3× 12TB HDD (TRAID) | 1× 1TB NVMe | 1× 500GB NVMe
greentower
Post by greentower »
F4-424 Pro(BIOS MADN0101.V05): update ok
F4-425 Plus(BIOS MTWL0101.V05): update ok
F5-422(BIOS MAPL0304V22): update ok
F4-423(BIOS 5.19): update ok
nitzer71 wrote: ↑28 Jul 2026, 11:35
You can manually perform a "Scan Media Library" once from the console to reset the monitoring trigger mechanism. This action will override any lingering monitoring status judgments left from before the update and remove the "do not monitor" configuration lock.
App updates are already in the pipeline; certain features currently shown as "disabled" are also being progressively optimized.
nitzer71
Australia
Post by nitzer71 »
RyanYang wrote: ↑28 Jul 2026, 14:39
Thank you for your suggestion.
I performed a full library scan as recommended. After the scan completed, I added a new movie to the monitored media folder.
Unfortunately, the movie was still not detected automatically by Plex or Jellyfin. Manual library scans detect the movie correctly, but real-time monitoring is still not working as it did under TOS 6.
This issue started after upgrading from TOS 6 to TOS 7.
snapsh0t
Post by snapsh0t »
Media Index Last run now shows correct 'summer' time.
Disks seem to be going to sleep correctly.
That's the last two major bugs off my list. :)
<A bit later> I may have been over-enthusiastic about reporting the disk sleeping. Yes, they are going to sleep after the set time but they're waking up soon afterwards. I'll try to check later with some more precise timing.
F2-425 Plus (N150), 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
nitzer71 wrote: ↑28 Jul 2026, 15:11
You can go to Settings > Library in Plex and check whether both "Scan my library automatically" and "Run a partial scan when changes are detected" are enabled. Additionally, if your NAS is currently performing other tasks, we recommend waiting a moment. Real-time monitoring does not always respond immediately to file additions or removals; occasional delays may occur.
nitzer71
Australia
Post by nitzer71 »
RyanYang wrote: ↑28 Jul 2026, 16:26
Thank you for your reply.
I have checked the Plex Library settings and both "Scan my library automatically" and "Run a partial scan when changes are detected" are enabled.
I also waited after adding new media files to allow time for detection, but the files were still not detected automatically.
Manual library scans work correctly and detect the new media, but real-time monitoring is still not working as it did under TOS 6.
The same Plex/Jellyfin setup worked correctly before upgrading from TOS 6 to TOS 7.
EriChan
Post by EriChan »
nitzer71 wrote: ↑28 Jul 2026, 16:37
We need to check this issue remotely. Please contact the online technical support staff through the following link to schedule remote technical support and attach the forum link and your forum ID as well:
