Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Important: This update is only applicable to TOS 7.0.0746 and newer. Users with older versions must first upgrade to 7.0.0746 before applying this update.
Here, we sincerely thank @Andy2026, @EgorA, @greentower, @Gremlin, @rfbjr, @DCCentR, @petrose, @crisisacting, @Pe6yc, @jayjay, @nitzer71, @chlor12, @joka388, @Metrogeek, @FredMutter, @nikk, @PIK, @Konstantin, @star, @snapsh0t, @Bartman, @quella, @ambul, @sianderson, @drduszek, @Zymphad and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Update Notes
Bug Fixes:
1. Fixed an issue where SMB remote folders might not be automatically mounted after a system update.
2. Fixed an issue where opening the same file multiple times in File Manager would generate multiple players.
3. Fixed an issue where overlapping message notifications might cause display anomalies in certain situations.
4. Fixed an issue where individual icons were not aligned correctly when sorting in the Safari browser.
5. Fixed an issue where some application icons displayed abnormally after an update.
6. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS mobile for Android:You can also search for "TNAS mobile" in the app store to install.
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
TOS 7.0.0780 (X86) is Released for Update
Re: TOS 7.0.0780 (X86) is Released for Update
Has the real-time library monitoring issue for Plex and Jellyfin been fixed in the new TOS 7.0.0780 update, allowing automatic file detection to work correctly again?
F4-425 Plus | 16GB RAM | Intel(R) N150 | 3× 12TB HDD (TRAID) | 1× 1TB NVMe | 1× 500GB NVMe
This issue has not been fixed in this version and will be addressed in a future release.
Updated without issue.
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
1 X 2TB (SSD) Hyper Cache
- greentower
F4-424 Pro(BIOS MADN0101.V05): update ok
F4-425 Plus(BIOS MTWL0101.V05): update ok
F5-422(BIOS MAPL0304V22): update ok
F4-423(BIOS 5.19): update ok
F2-221 TOS7.0.1422 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1341 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
- Konstantin
Hello, today after the automatic update to this version (.80), one of the two drives in the mirrored RAID array on a supported NVMe drive (a Kingston KC3000) crashed.
I haven't resolved the issue yet. Everything was fine before. The F8 SSD Plus didn't make any noise.
I updated all three of my devices via the mobile app, all updated w/o issues. It was more of convivence this morning to do it that way.
F6-424 & F4-425 Plus at 7.0.1341
F4-424 Pro (x2) at 7.0.1341
- sianderson
- Silver Member
how often does TOS check for new updates? i have mine set to email me but so far i haven’t received an email to tell me a new version is available
after the installation i do get the email from both my NAS's to tell me its installed / rebooted etc so i know its set up correctly to email me
F2-424 TOS 7.0.1341
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
