I can only see about 10 apps to be installed under "All Apps" in the App Center. Wondering why with TOS v7 I'm not seeing any option to install TerraSync.
Thanks.
Quella
TerraSync not showing as option in "all apps" on TOS v7
Re: TerraSync not showing as option in "all apps" on TOS v7
A Mystery. Which version of Tos7?
(There are many more than 10 apps listed.)
Hey @gremlin. Yes, I recently upgraded from v6 to the release of v7. I'm not sure yet if it has to do with my network firewall blocking some traffic, so I opened it up at this point. I'm not sure if there is a way to force a check-in and show any app updates, etc. It was never an issue with v5 or v6, I had 50+ apps listed. Very strange indeed. I may give it a day or so with unlimited outbound access and see if it corrects itself.
If you can only see a limited number of apps in the App Center, the issue may be related to your network connection; please verify that your NAS has a stable network connection. You can try temporarily disabling firewall restrictions to see if more apps become available.
