[Help] Plex, Emby, Jellyfin not updating with new files  [SOLVED]
digi999
Post by digi999 »
just upgraded to latest TOS7 , checked all apps and live scanning for changes etc are still enabled , worked fine under TOS6 but when I add media to my media folders (Movies etc) the new media isn't snanned into the library on Plex , Jellyfin and Emby. A manual scan however detetcts them. Anyone else getting this issue ?
many thanks :)
EriChan
Re: [Help] Plex, Emby, Jellyfin not updating with new files
Post by EriChan »
digi999 wrote: 03 Jul 2026, 14:42
Is the version number of the Jellyfin application the latest 10.11.15?
digi999
Post by digi999 »
it is but its also an issue with Plex (latest) and Emby (latest) all running on the same NAS , same folder permissions etc and were working perfectly OK under TOS 6 which makes me beleive its a TOS 7 monitoring / call error
EriChan
Post by EriChan »
digi999 wrote: 04 Jul 2026, 15:18
Based on your description, it is likely an issue of permissions. Could you please confirm whether you have enabled SPC mode?
digi999
Post by digi999 »
No SPC isn't enabled
So, are you saying that after upgrading from TOS6 to TOS7, these three apps can still detect new media files through a manual scan, but they no longer automatically update when you add new media folders?
We’ll look into this and try to reproduce the issue you mentioned.
digi999
Post by digi999 »
TMzethar wrote: 05 Jul 2026, 10:35 Hi,
Thats correct
We're sorry to hear about the issues you're experiencing with these three apps. We've recorded your feedback and will verify the situation. We'll be sure to inform you of any developments.
Re: [Help] Plex, Emby, Jellyfin not updating with new files  [SOLVED]
Based on the information currently available, this issue is related to a system permission error and is currently being investigated and resolved. Please wait for a future update to resolve this issue.
digi999
Post by digi999 »
issue still there after latest TOS update but you've already said it'll be picked up in a future update so thankyou
Return to “File Services”
