TOS 7.0.0765 Official Release (X86) is Now Available
Target Users:
Users currently running TOS 7.0.0746 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 update instructions first.
Here, we sincerely thank @B0rg, @rfbjr, @crisisacting, @AlexNo, @ATO3FIX, @star, @Renzz, @Gremlin, @gustang, @JAW, @sewtery, @joka388, @polen, @solovei2, @snapsh0t, @Vanekjin, @Nitrokalel, @greentower, @JSCFORCE, @rcruzleroux, @mab, @Lex, @mnewland, @Metrogeek, @usersky, @Pe6yc, @sianderson, @jpeckinp, @Tessi, @BFG, @FredMutter, @Joesh, and @OttO1916 for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Update Notes
Bug Fixes:
1. Fixed an issue where File Manager might fail to start after the update.
2. Fixed an issue where key files in /etc/ssh changed after the update.
3. Fixed an issue where the proxy feature might fail to enable in certain special cases.
4. Fixed an issue where the SNMP service could not start properly.
5. Fixed an issue where the storage pool composition information might be displayed incorrectly in certain special cases.
6. Fixed an issue where users could not log in after renaming a user or user group.
7. Fixed an issue where mounting MEGA and OpenDrive cloud drives failed.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS mobile 3.5.077 for Android. (You can also search for "TNAS mobile" in the app store to install.)
6. TNAS Mobile for iOS: Please search for "TNAS mobile" in the App Store to install.
Note:
Update Notes
Bug Fixes:
Update Procedure:
Client Downloads:
- crisisacting
- Silver Member
Re: TOS 7.0.0765 Official Release (X86) is Now Available
Updated testbed devices; so far so good.
Will test throughout this week & next for any issues.
- thierrys73
hello
The update went smoothly on my F2-221 and my T6-423.
However, it seems to me that the remote folders aren't mounting automatically, even though the option is checked.
thanks
thanks
Tnas T6-423
Tnas F2-221
Tnas F2-221
"Update failed! The update decompression failed. Please try again later."
F8 SSD Plus, trying update from 7.0.0746.
UPD: Manual installation -> Success.
In my case remote folders did auto-mount.thierrys73 wrote: ↑30 Jun 2026, 14:38
Updated F2-221, F2-424, F2-425+. No apparent issues with the update.
All three devices updated without issues.
F4-424 Pro also at 7.0.0777
D4-320
D4-320
Hello, to help us quickly identify the issue, please provide the following information:thierrys73 wrote: ↑30 Jun 2026, 14:38 hello
thanks
1.Remote mount configuration
Please provide the type of remote folder (SMB / WebDAV / NFS / cloud drive).
Also confirm whether all remote folders fail to auto-mount.
2.Log information
Open the Terminal application and run:
systemctl status clouddisk.serviceWe will also try to reproduce the issue on our side and help you identify the root cause as soon as possible.
F5-422 after update to 7.0.0765 TerraSync backup task couldn'r find a backup folder on the NAS. I recreated the task and backup works normal
- thierrys73
TMchris wrote: ↑30 Jun 2026, 19:07Hello, to help us quickly identify the issue, please provide the following information:thierrys73 wrote: ↑30 Jun 2026, 14:38 hello
thanks
2.Log information
Open the Terminal application and run:Please send us the output result.Code: Select all
Hello
SMB
answer of the command
○ clouddisk.service - Cloud Disk Tool
Loaded: loaded (/lib/systemd/system/clouddisk.service; static)
Active: inactive (dead)
Tnas T6-423
Tnas F2-221
Tnas F2-221
