[Help] D5 Hybrid - random disconnects
lemonSqueezy
Post by lemonSqueezy »
I am running a single Nvme SSD on the D5 Hybrid. Windows 11 Pro.
I have been experiencing random disconnects from the D5 Hybrid.
I found this post for a TerraMaster diagnostic/firmware update tool but am having issues with the tool itself.
I can actually access the Nvme on the D5 Hybrid through the Windows explorer and manipulate files. But when I run the TerraMaster application, I cannot see the drive and there is a "Device not found" error at the bottom.
I can also see the drive via Disk Management. It's very strange that I cannot view it on the TerraMaster software.
Please advise.
lemonSqueezy
Re: [Help] D5 Hybrid - random disconnects
My apologies, this was a problem on my side.
I disabled the "Parsec Virtual USB Adapter" in Device Manager, ran the TerraMaster app again and the Nvme connected to the TerraMaster showed-up correctly.
I went through the update steps and confirm that the update went through properly.
Sorry about the confusion, and thank you to the TerraMaster team for addressing this issue.
I do have one question: if I install another Nvme SSD into the D5 Hybrid, do I have to go through the same update process for that one, too?
Thank you very much.
EriChan
Post by EriChan »
Thank you for your detailed feedback.
The update and upgrade process primarily targets the M.2 slot rather than the hard drive, but it requires the hard drive's cooperation.
For example, if you currently want to upgrade other M.2 slots of the Hybrid but only have one M.2 NVMe SSD, you can install the M.2 NVMe SSD into another M.2 slot after the current upgrade operation is complete, and then continue clicking to upgrade.
lemonSqueezy
Thank you for the clarification. I understand (in layman's terms) that, in order for the M.2 slot to be updated, it requires an M.2 SSD to be physically connected.
I'll connect my current M.2 to the second slot in the D5 Hybrid, then update that.
Ah, sorry, one more question: since I am currently only using one M.2 slot (the other HDD/SSD slots are empty).
Would I also need to update those 3.5"/2.5" slots with the upgrade tool, as well?
Thanks for the help.
EriChan
Post by EriChan »
lemonSqueezy wrote: ↑29 Jun 2026, 09:44
You do not need to use the upgrade tool to update the 3.5-inch/2.5-inch drive bays, this update only applies to the M.2 NVMe SSD serial number duplication and disconnection issues on the D5/D8 Hybrid.
Return to “USB Series”
