TOS 7.0.0616 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0601 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first.
Important: This update is only applicable to TOS 7.0.0601 and newer. Users with older versions must first upgrade to 7.0.0601 before applying this update.
Here, we sincerely thank users @Andy2026, @dgmigdot, @rfbjr, @Gremlin, @weerasak, @mnewland, @Nitrokalel, @OttO1916, @crisisacting, @snapsh0t, @TMEmily, @exqo, @Zymphad, @EriChan, @yxyx999, @philou669, @Tessi and others for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bug Fixes:
1. Fixed an issue where error messages might not be triggered in a timely manner when uploading files with insufficient volume capacity.
2. Fixed an issue where clicking was still possible on some pages after a mask overlay was displayed.
3. Fixed an issue where an incorrect prompt appeared for grayed-out buttons in the storage pool module.
4. Fixed an issue where newly added content might not display correctly after updating an application.
5. Fixed an issue where dragging multiple files simultaneously while uploading files in File Manager could cause the upload to fail.
6. Fixed an issue where the status of Docker-dependent applications might not update in a timely manner.
7. Fixed an issue where the application status on the web end did not update correctly when stopping an application via TNAS mobile.
8. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS Mobile 3.5.068 for Android.
6. TNAS Mobile for iOS: To be released
Note:
Update Notes
Bug Fixes:
Update Procedure:
Client Downloads:
Request to completely remove stuck menu shortcuts for OpenClaw and Jellyfin (TOS 7 Beta Feedback - @weerasak)
Dear TerraMaster Support Team / RyanYang,
First of all, thank you for mentioning my username (@weerasak) in the latest TOS 7.0.0616 Beta release notes. I am very glad to contribute feedback to improve the system.
I am writing to report a persistent issue that started in the previous version and is still affecting my system. I have been unable to install the OpenClaw application via the App Center (it always results in an "Install Fail" status).
Moreover, even though the installations failed or were canceled, the shortcut icons for both OpenClaw and Jellyfin are now permanently stuck on my TOS desktop/menu tab. I cannot delete or uninstall them through the regular user interface.
I would like to request your guidance or a fix to completely remove and purge these stuck menu shortcuts from my system so they no longer appear.
I have attached the relevant system logs to this email for your analysis.
Thank you for your continuous support and for making TOS 7 better.
Best regards,
Weerasak
(TOS Forum Username: @weerasak)
Best regards,
Weerasak
Re: TOS 7.0.0616 Beta (X86) is Released for Update
All three devices updated with no issues. Testing later today.
F4-424 Pro (x2) at 7.0.1298
Re: Request to completely remove stuck menu shortcuts for OpenClaw and Jellyfin (TOS 7 Beta Feedback - @weerasak)
Hi weerasak,
Before we dive deeper, I'd like to confirm two things with you:
1. Are you currently able to install other apps normally?
2. Have you previously tried installing this app on different volumes?
If you originally selected Volume 1 for installation, please open the Terminal from "All Applications" on the TOS desktop, then copy and paste the following command (please be sure to copy and paste, do not type it manually to avoid typos):
rm -r /Volume1/@apps/openclawhttps://download3.terra-master.com/Apps ... x86_64.deb
Regarding the stuck shortcut icons: please log in with an admin account, right-click the app icon on the navigation bar, and you should see a "Remove from Bar" option — click it to remove.
Feel free to let us know if you have any progress updates or further questions. We're happy to continue assisting.
- Nitrokalel
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod) update ok
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, beta)update ok
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, beta) update ok
F2-423 (2x18TB, TRaid, 32GB, beta) update ok
F2-221 (6TB+10TB, TRaid, 10GB, beta) update ok
D1 SSD (2TB, prod) is recognized and read
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
D1 SSD (2TB, prod)
F2-425 Plus updated from 7.0.0612 to 7.0.0616 and all seems well.
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB SN700 EXT4 RAID10, TOS 7.0.<latest>
just updated and the TNAS is just beeping every 1 or 2 secs I can't log in and using the windows PC app it shows the NAS ready but can't login. looks to me as if the update didn't work for me F5-221 was running TOS 7.0.612 I think . The constant beeping suggests to me that I need to reinstall the OS ?
Please plug one HDMI monitor to observe output and provide screenshot for analysis
A beep every 1-2 seconds and unable to log in usually means a degraded array or Hyper Cache error causing the system to keep retrying. Try the following steps:Tom wrote: ↑03 Jun 2026, 06:16 just updated and the TNAS is just beeping every 1 or 2 secs I can't log in and using the windows PC app it shows the NAS ready but can't login. looks to me as if the update didn't work for me F5-221 was running TOS 7.0.612 I think . The constant beeping suggests to me that I need to reinstall the OS ?
1. Wait 5-10 minutes first — the system may be rebuilding or verifying in the background, and it might recover on its own.
2. If still not working, shut down, reseat all drives firmly, and power back on.
3. If you've created a Hyper Cache, shut down, remove the cache SSD, and power on again.
Are you able to log in now? If so, please check the status of any abnormal disks.
Version 0.0.247 Installation failed!RyanYang wrote: ↑02 Jun 2026, 20:41Hi weerasak,
If you originally selected Volume 1 for installation, please open the Terminal from "All Applications" on the TOS desktop, then copy and paste the following command (please be sure to copy and paste, do not type it manually to avoid typos):After it's done, try installing the app again. You can also download the version below first, then install it manually:Code: Select all
