[Help] Is this normal for a RAID repair?
Belve1949
Virgin Islands (USA)
Post by Belve1949 »
I installed a new HDD in my T6-423 this morning and had it start repairing my RAID. I was replacing a WD Red 4TB with a WD Red 18TB. I have 6 drives in a TRAID set up. Everything seemed normal for the first hour, but now I can no longer connect to my NAS. It can't be found anywhere on my network, it wont even show in my router that it is connected. Is this normal for a RAID repair?
Storage enthusiast | TerraMaster fan | Always tinkering with RAID setups solitaire
MikeZhang
Re: [Help] Is this normal for a RAID repair?
Post by MikeZhang »
Belve1949 wrote: 21 May 2026, 15:25
1.Sorry for the inconvenience, please check if ssh connection still works viewtopic.php?f=78&t=2350
2.If it doesn't work, you may plug one HDMI monitor to your T6-423, then restart NAS by power button, record monitor output and send it to us support at terra-master.com together with this forum link, or PM us, we will analyze for you carefully
