TOS 6.0.535 (X86) is Released for Update
TMeric
Re: TOS 6.0.535 (X86) is Released for Update
Post by TMeric »
desallesp wrote: 03 Dec 2024, 00:51
Tom wrote: 27 Nov 2024, 05:59 Is there any update on UPS issue where it only works for 30mins to 1 hour then the checkbox for Enable UPS Support becomes unticked and if you try to enable UPS support it can't detect the UPS until the NAS is rebooted ?
Did you get any news on this? I have the same occurring to me on a new F4 424 Pro
Could you please provide the specific model of your UPS? We need to verify it.
desallesp
Post by desallesp »
TMeric wrote: 03 Dec 2024, 20:39
In my case, it's a CYBERPOWER CP1500AVRLCD, when I first boot I do see it then after about 30 minutes it no longer reads the information off itand the "Enable UPS Support" checkbox unticks itself.
desallesp wrote: 03 Dec 2024, 21:11
Suggest you use the search function to check previous posts on this forum. Cyberpower seems to come up most frequently when there are issues with ups function. (Particularly when the ups model is supposedly on compatibility list)
sandypatel
Australia
Post by sandypatel »
last month i purchase F4-424 PRO nas and upgraded to latest TOS 6.0.535
my NAS drop network connection when my router rebooted and wont reconnect after router up and running. the only workaround i have to do is unplug the network cable and then plug again though i have to repeat this process two times. if i unplug the network cable and plug only one time it wont connect to network and i have to repeat the process for the second time to fix the issue.
i have send the NAS logs to support team as well for review
jhnbrg
Germany
Post by jhnbrg »
Hello everyone.
I have one TNAS F4-423 with two Volumes. The operating system is TOS6 6.0.535. I have problems with Emby Server (4.8.8.0) permissions when creating libraries. I have no access to media folders on my TNAS. All permissions are set. More infos in my topic:
viewtopic.php?t=6994
Any ideas how to fix this problem?
F4-423
lsoto
Post by lsoto »
I was super happy with TOS6 2039.
It is some days I upgraded to 530, but on reboot it auto-updated to 535.
Since then a nightmare
- A) my 1.4Tb cache balanced started to took 14Gb of my memory (I only have 16Gb) so it started to swapping
- B) Every time I access a smb share it hangs
[45973.316744] ------------[ cut here ]------------
[45973.316749] refcount_t: underflow; use-after-free.
[45973.316765] WARNING: CPU: 2 PID: 733287 at lib/refcount.c:28 refcount_warn_saturate+0xd8/0xe0
[45973.316773] Modules linked in: aesni_intel crypto_simd cryptd kvm_intel kvm irqbypass i915 drm_buddy video wmi drm_display_helper drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm atlantic scst_raid(O) scst_user(O) scst_disk(O) scst_vdisk(O) isert_scst(O) iscsi_scst(O) scst(O) 88x2bu(O) 8812au(O)
[45973.316795] CPU: 2 PID: 733287 Comm: smbd Tainted: G O 6.1.58+ #208
[45973.316798] Hardware name: retsamarret 000-T6423-UK000-2000-N/Default string, BIOS 5.19 07/06/2022
[45973.316799] RIP: 0010:refcount_warn_saturate+0xd8/0xe0
[45973.316803] Code: ff 48 c7 c7 20 c5 17 89 c6 05 a7 b1 9c 01 01 e8 fe 2d 8b ff 0f 0b c3 48 c7 c7 c8 c4 17 89 c6 05 93 b1 9c 01 01 e8 e8 2d 8b ff <0f> 0b c3 0f 1f 44 00 00 8b 07 3d 00 00 00 c0 74 12 83 f8 01 74 13
[45973.316805] RSP: 0018:ffffa98ec30cfe58 EFLAGS: 00010286
[45973.316807] RAX: 0000000000000000 RBX: ffff9668411dfc64 RCX: 0000000000000000
[45973.316809] RDX: 0000000000000002 RSI: 0000000000000027 RDI: 00000000ffffffff
[45973.316810] RBP: 0000000000000000 R08: 00000000ffffdfff R09: 0000000000000001
[45973.316811] R10: 00000000ffffdfff R11: ffffffff8945f340 R12: ffff9668062ac258
[45973.316812] R13: ffffffff894577e0 R14: 0000000000000001 R15: ffff9668411dfc74
[45973.316814] FS: 00007fa2262e8ec0(0000) GS:ffff966b6ff00000(0000) knlGS:0000000000000000
[45973.316816] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[45973.316817] CR2: 0000555b615ae040 CR3: 0000000106f4b000 CR4: 0000000000350ee0
[45973.316819] Call Trace:
[45973.316821] <TASK>
[45973.316822] ? refcount_warn_saturate+0xd8/0xe0
[45973.316825] ? __warn+0x74/0xc0
[45973.316830] ? refcount_warn_saturate+0xd8/0xe0
[45973.316833] ? report_bug+0xe2/0x170
[45973.316836] ? prb_read_valid+0x12/0x20
[45973.316839] ? handle_bug+0x36/0x70
[45973.316843] ? exc_invalid_op+0x13/0x60
[45973.316844] ? asm_exc_invalid_op+0x16/0x20
[45973.316848] ? refcount_warn_saturate+0xd8/0xe0
[45973.316850] ? refcount_warn_saturate+0xd8/0xe0
[45973.316852] posix_acl_permission+0x34e/0x3a0
[45973.316856] generic_permission+0x18a/0x1e0
[45973.316860] inode_permission+0x30/0x140
[45973.316862] __x64_sys_chdir+0x5d/0xe0
[45973.316866] do_syscall_64+0x35/0x80
[45973.316870] entry_SYSCALL_64_after_hwframe+0x46/0xb0
[45973.316872] RIP: 0033:0x7fa22a514f8b
[45973.316875] Code: c3 66 0f 1f 44 00 00 48 8b 15 a1 3e 10 00 f7 d8 64 89 02 b8 ff ff ff ff eb c0 0f 1f 44 00 00 f3 0f 1e fa b8 50 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 75 3e 10 00 f7 d8 64 89 01 48
[45973.316876] RSP: 002b:00007fff457ae248 EFLAGS: 00000206 ORIG_RAX: 0000000000000050
[45973.316879] RAX: ffffffffffffffda RBX: 0000000000000007 RCX: 00007fa22a514f8b
[45973.316880] RDX: 000000000000001c RSI: 0000555b615aeb80 RDI: 0000555b615aeb80
[45973.316881] RBP: 00007fa22a9cd600 R08: 000000000000ff90 R09: 0000000000000ac0
[45973.316882] R10: 00007fa22ac3d880 R11: 0000000000000206 R12: 0000000000000007
[45973.316883] R13: 00007fa22ac3d8b0 R14: 00007fa22ac2c470 R15: 00007fa22ac2c4a8
[45973.316885] </TASK>
[45973.316886] ---[ end trace 0000000000000000 ]---
[45978.720033] ------------[ cut here ]------------
[45978.720038] WARNING: CPU: 2 PID: 729160 at mm/slab_common.c:923 free_large_kmalloc+0x4e/0x70
[45978.720046] Modules linked in: aesni_intel crypto_simd cryptd kvm_intel kvm irqbypass i915 drm_buddy video wmi drm_display_helper drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm atlantic scst_raid(O) scst_user(O) scst_disk(O) scst_vdisk(O) isert_scst(O) iscsi_scst(O) scst(O) 88x2bu(O) 8812au(O)
[45978.720069] CPU: 2 PID: 729160 Comm: kworker/2:0 Tainted: G W O 6.1.58+ #208
[45978.720072] Hardware name: retsamarret 000-T6423-UK000-2000-N/Default string, BIOS 5.19 07/06/2022
[45978.720073] Workqueue: events kfree_rcu_work
[45978.720079] RIP: 0010:free_large_kmalloc+0x4e/0x70
[45978.720082] Code: da 9c 41 5c fa be 06 00 00 00 48 89 df e8 da 95 07 00 41 f7 c4 00 02 00 00 74 01 fb 89 ee 48 89 df 5b 5d 41 5c e9 22 61 03 00 <0f> 0b 80 3d de bb f6 01 00 0f 84 5a ec f2 00 ba 00 f0 ff ff 31 ed
[45978.720084] RSP: 0018:ffffa98ec8727d90 EFLAGS: 00010246
[45978.720086] RAX: 0020000000001000 RBX: fffff65d084815c0 RCX: 00000000802a0005
[45978.720088] RDX: 0000000208c00000 RSI: ffffffff894577e0 RDI: fffff65d084815c0
[45978.720089] RBP: ffff966800042600 R08: 0000000000000025 R09: ffffffff894577e0
[45978.720090] R10: fffff65d00b2fa00 R11: 0000000000000006 R12: 0000000000000000
[45978.720091] R13: ffff9669144a2010 R14: fffff65d084815c0 R15: ffff9668b16f5f60
[45978.720093] FS: 0000000000000000(0000) GS:ffff966b6ff00000(0000) knlGS:0000000000000000
[45978.720094] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[45978.720096] CR2: 00007f144c0d6818 CR3: 000000010c16b000 CR4: 0000000000350ee0
[45978.720097] Call Trace:
[45978.720100] <TASK>
[45978.720101] ? free_large_kmalloc+0x4e/0x70
[45978.720104] ? __warn+0x74/0xc0
[45978.720108] ? free_large_kmalloc+0x4e/0x70
[45978.720110] ? report_bug+0xe2/0x170
[45978.720113] ? handle_bug+0x36/0x70
[45978.720116] ? exc_invalid_op+0x13/0x60
[45978.720117] ? asm_exc_invalid_op+0x16/0x20
[45978.720121] ? free_large_kmalloc+0x4e/0x70
[45978.720123] kmem_cache_free_bulk.part.0+0x579/0x610
[45978.720126] ? kfree_rcu_work+0x2e9/0x410
[45978.720129] ? _raw_spin_unlock+0xd/0x20
[45978.720131] ? finish_task_switch.isra.0+0x8d/0x2b0
[45978.720133] kfree_rcu_work+0x2e9/0x410
[45978.720137] process_one_work+0x1ca/0x390
[45978.720140] worker_thread+0x45/0x3a0
[45978.720142] ? _raw_spin_lock_irqsave+0x12/0x40
[45978.720144] ? rescuer_thread+0x390/0x390
[45978.720147] kthread+0xe1/0x110
[45978.720149] ? kthread_complete_and_exit+0x20/0x20
[45978.720151] ret_from_fork+0x1f/0x30
[45978.720155] </TASK>
[45978.720156] ---[ end trace 0000000000000000 ]---
[45978.720157] object pointer: 0x0000000029957deb
[45979.243849] ------------[ cut here ]------------
[45979.243851] ------------[ cut here ]------------
[45979.243853] refcount_t: saturated; leaking memory.
[45979.243853] refcount_t: addition on 0; use-after-free.
[45979.243867] WARNING: CPU: 2 PID: 733405 at lib/refcount.c:22 refcount_warn_saturate+0x61/0xe0
[45979.243867] WARNING: CPU: 3 PID: 733407 at lib/refcount.c:25 refcount_warn_saturate+0x80/0xe0
[45979.243875] Modules linked in:
[45979.243876] Modules linked in: aesni_intel
[45979.243877] aesni_intel
[45979.243878] crypto_simd
[45979.243878] crypto_simd cryptd
[45979.243880] cryptd kvm_intel
[45979.243881] kvm_intel kvm
[45979.243882] kvm irqbypass
[45979.243883] irqbypass
[45979.243884] i915
[45979.243884] i915 drm_buddy
[45979.243885] drm_buddy video
[45979.243886] video
[45979.243887] wmi drm_display_helper
[45979.243888] wmi drm_display_helper
[45979.243889] drm_kms_helper
[45979.243890] drm_kms_helper
[45979.243890] syscopyarea sysfillrect
[45979.243891] syscopyarea sysfillrect
[45979.243892] sysimgblt
[45979.243892] sysimgblt fb_sys_fops
[45979.243893] fb_sys_fops ttm
[45979.243894] ttm atlantic
[45979.243895] atlantic scst_raid(O)
[45979.243896] scst_raid(O) scst_user(O)
[45979.243898] scst_user(O) scst_disk(O)
[45979.243899] scst_disk(O)
[45979.243900] scst_vdisk(O)
[45979.243900] scst_vdisk(O) isert_scst(O)
[45979.243901] isert_scst(O) iscsi_scst(O)
[45979.243902] iscsi_scst(O)
[45979.243903] scst(O)
[45979.243903] scst(O) 88x2bu(O)
[45979.243905] 88x2bu(O) 8812au(O)
[45979.243906] 8812au(O)
[45979.243908] CPU: 3 PID: 733407 Comm: TOSDaemon Tainted: G W O 6.1.58+ #208
[45979.243908] CPU: 2 PID: 733405 Comm: TOSDaemon Tainted: G W O 6.1.58+ #208
[45979.243911] Hardware name: retsamarret 000-T6423-UK000-2000-N/Default string, BIOS 5.19 07/06/2022
[45979.243913] RIP: 0010:refcount_warn_saturate+0x61/0xe0
[45979.243913] RIP: 0010:refcount_warn_saturate+0x80/0xe0
[45979.243916] Code: 05 28 b2 9c 01 01 e8 7e 2e 8b ff 0f 0b c3 80 3d 1c b2 9c 01 00 75 d7 48 c7 c7 70 c4 17 89 c6 05 0c b2 9c 01 01 e8 5f 2e 8b ff <0f> 0b c3 80 3d fc b1 9c 01 00 75 b8 48 c7 c7 98 c4 17 89 c6 05 ec
[45979.243916] Code: 05 0c b2 9c 01 01 e8 5f 2e 8b ff 0f 0b c3 80 3d fc b1 9c 01 00 75 b8 48 c7 c7 98 c4 17 89 c6 05 ec b1 9c 01 01 e8 40 2e 8b ff <0f> 0b c3 80 3d df b1 9c 01 00 75 99 48 c7 c7 70 c4 17 89 c6 05 cf
[45979.243918] RSP: 0018:ffffa98ec3237e48 EFLAGS: 00010282
[45979.243919] RSP: 0018:ffffa98ec3267e48 EFLAGS: 00010282
[45979.243921] RAX: 0000000000000000 RBX: ffff966811398d80 RCX: 0000000000000000
[45979.243921] RAX: 0000000000000000 RBX: ffff96681262c3c0 RCX: 0000000000000000
[45979.243923] RDX: 0000000000000002 RSI: 0000000000000027 RDI: 00000000ffffffff
[45979.243924] RBP: ffff966814c5e180 R08: 00000000ffffdfff R09: 0000000000000001
[45979.243925] RBP: ffff96681262c540 R08: 80000000ffffe544 R09: ffffa98ec3237dd0
[45979.243926] R10: 0000000000000001 R11: ffffffffffffffff R12: ffff96680aef4000
[45979.243926] R10: 00000000ffffdfff R11: ffffffff8945f340 R12: ffff9668110db000
[45979.243927] R13: 0000000000000000 R14: ffff96684087af80 R15: 000000c001915ea0
[45979.243928] R13: 0000000000000000 R14: ffff9668001f97c0 R15: 000000c0037e9900
[45979.243929] FS: 00007f3dbffff640(0000) GS:ffff966b6ff80000(0000) knlGS:0000000000000000
[45979.243929] FS: 00007f3dbcff9640(0000) GS:ffff966b6ff00000(0000) knlGS:0000000000000000
[45979.243931] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[45979.243933] CR2: 00007fdc9805d0d8 CR3: 000000013f7a9000 CR4: 0000000000350ee0
[45979.243933] CR2: 00007efd68366000 CR3: 000000013f7a9000 CR4: 0000000000350ee0
[45979.243935] Call Trace:
[45979.243937] <TASK>
[45979.243939] ? refcount_warn_saturate+0x61/0xe0
[45979.243939] ? refcount_warn_saturate+0x80/0xe0
[45979.243942] ? __warn+0x74/0xc0
[45979.243941] ? __warn+0x74/0xc0
[45979.243946] ? refcount_warn_saturate+0x61/0xe0
[45979.243946] ? refcount_warn_saturate+0x80/0xe0
[45979.243949] ? report_bug+0xe2/0x170
[45979.243953] ? prb_read_valid+0x12/0x20
[45979.243952] ? handle_bug+0x36/0x70
[45979.243955] ? exc_invalid_op+0x13/0x60
[45979.243956] ? handle_bug+0x36/0x70
[45979.243958] ? exc_invalid_op+0x13/0x60
[45979.243957] ? asm_exc_invalid_op+0x16/0x20
[45979.243960] ? asm_exc_invalid_op+0x16/0x20
[45979.243962] ? refcount_warn_saturate+0x80/0xe0
[45979.243963] ? refcount_warn_saturate+0x61/0xe0
[45979.243964] ? refcount_warn_saturate+0x80/0xe0
[45979.243965] ? refcount_warn_saturate+0x61/0xe0
[45979.243967] prepare_creds+0x1f1/0x200
[45979.243968] prepare_creds+0x1e2/0x200
[45979.243971] prepare_exec_creds+0x6/0x50
[45979.243975] bprm_execve+0x52/0x610
[45979.243974] bprm_execve+0x52/0x610
[45979.243978] do_execveat_common.isra.0+0x1a8/0x220
[45979.243980] __x64_sys_execve+0x2d/0x40
[45979.243981] __x64_sys_execve+0x2d/0x40
[45979.243983] do_syscall_64+0x35/0x80
[45979.243987] entry_SYSCALL_64_after_hwframe+0x46/0xb0
[45979.243989] RIP: 0033:0x7f3dcee499ae
[45979.243991] Code: 24 28 44 8b 44 24 2c e9 70 ff ff ff cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc 49 89 f2 48 89 fa 48 89 ce 48 89 df 0f 05 <48> 3d 01 f0 ff ff 76 15 48 f7 d8 48 89 c1 48 c7 c0 ff ff ff ff 48
[45979.243992] Code: 24 28 44 8b 44 24 2c e9 70 ff ff ff cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc cc 49 89 f2 48 89 fa 48 89 ce 48 89 df 0f 05 <48> 3d 01 f0 ff ff 76 15 48 f7 d8 48 89 c1 48 c7 c0 ff ff ff ff 48
[45979.243993] RSP: 002b:000000c0047ab380 EFLAGS: 00000216
[45979.243994] RSP: 002b:000000c0054bb380 EFLAGS: 00000216 ORIG_RAX: 000000000000003b
[45979.243995] ORIG_RAX: 000000000000003b
[45979.243996] RAX: ffffffffffffffda RBX: 000000c001e2a740 RCX: 00007f3dcee499ae
[45979.243997] RAX: ffffffffffffffda RBX: 000000c00273eb20 RCX: 00007f3dcee499ae
[45979.243998] RDX: 000000c001915ea0 RSI: 000000c00547e1a0 RDI: 000000c001e2a740
[45979.243998] RDX: 000000c0037e9900 RSI: 000000c003ff70e0 RDI: 000000c00273eb20
[45979.243999] RBP: 000000c0054bb3c0 R08: 0000000000000000 R09: 0000000000000000
[45979.244000] RBP: 000000c0047ab3c0 R08: 0000000000000000 R09: 0000000000000000
[45979.244001] R10: 0000000000000000 R11: 0000000000000216 R12: 00007f3dcee9f786
[45979.244002] R13: 0000000000000000 R14: 000000c000104fc0 R15: 000000000983cecd
[45979.244003] R13: 0000000000000000 R14: 000000c004747180 R15: 000000000983cecd
[45979.244005] </TASK>
[45979.244006] ---[ end trace 0000000000000000 ]---
[45979.244007] ---[ end trace 0000000000000000 ]---
IT Infrastructure/SRE
XT9 Mesh, HomeLab, Syn DS920+, Terramaster T6-423,F4-424Pro, MacBook, HyperOptic 1Gb ipv6.
lsoto wrote: 04 Dec 2024, 17:35
I would suggest you delete the hypercache and reassess your requirements. I think 1.4TB is too large (The 14GB ram sounds about right for the currently assigned size of cache).
TMtina
Post by TMtina »
sandypatel wrote: 04 Dec 2024, 09:33 last month i purchase F4-424 PRO nas and upgraded to latest TOS 6.0.535
We have noticed the issue and will address it in future TOS system updates. Please stay tuned for update notifications.
TMtina
Post by TMtina »
jhnbrg wrote: 04 Dec 2024, 16:50 Hello everyone.
Please edit the shared folder in Control Panel - Shared Folder, check 'Replace permissions of all subdirectories with permissions of the folder' and try again.
jhnbrg
Germany
Post by jhnbrg »
It doesn't work. When I try to check 'Replace permissions of all subdirectories with permissions of the folder', nothing happens. This setting is not applied, even after several attempts.
Image Image Image
F4-423
