TOS 6.0.535 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.500 or later versions.
Note: If your TOS version does not meet the requirements, please first check the update conditions for TOS 6.0.530.
Warning!
  • This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need.
Update Notes
Bug fixes:
1. Fixed the issue that log archives packaged in Debug mode could not be deleted.
2. Fixed the issue that permissions changed to read-write when copying read-only folders with Snapshot.
3. Fixed the issue that the permissions page did not automatically refresh after formatting a USB device.
4. Fixed the issue that hardware information in the resources panel was not displaying correctly.
5. Fixed the issue that an error occurred when setting custom permissions for the recycle bin folder.
6. Fixed the issue that new files could not be uploaded after a network disconnection and reconnection.
7. Fixed the issue that video thumbnails were not displayed when opening shared links on a computer.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.003.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.3.027 for Android:
https://download2.terra-master.com/TNAS ... .3.027.apk
TNAS Mobile for iOS: Download from the iOS App Store.
ellowsmile
Re: TOS 6.0.535 (X86) is Released for Update
Post by ellowsmile »
oh, new update. I'm waiting for someone to say that everything is fine with it and I can install it)
F4-423
DCCentR
Post by DCCentR »
ellowsmile wrote: 14 Nov 2024, 14:19 oh, new update. I'm waiting for someone to say that everything is fine with it and I can install it)
Upgraded from TOS 6.0.519 - so far so good :D
F4-424 Pro
gaz2k1uk
Post by gaz2k1uk »
Updated from TOS 6.0.530 without issue, did have to disable and re-enable Plex in order to connect as it did not find the folders but once done connects fine. Running Plex and USB copy.
Setup:
System: F2-422
OS: TOS 6.0.535
HD: x2 IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
Updated. At least the system monitoring works now. ;)
star
Sweden
Post by star »
network port 2 is shifting ip adress nonstop every hour for unknown reason. despite being set to static. it jumps ip adress.
star wrote: 14 Nov 2024, 20:26 network port 2 is shifting ip adress nonstop every hour for unknown reason. despite being set to static. it jumps ip adress.
Is that shifting within the set lan segment? Shifting within the allocated DHCP pool? Is there a conflict between DHCP pool range and static setting on nas?
bugacha
Algeria
Post by bugacha »
I'm upgrading from 519, how come not a word that SSH port automatically changes from 22 to 9222 without warning user !??
bugacha
Algeria
Post by bugacha »
Otherwise I just upgraded, all good
Bartman
Post by Bartman »
bugacha wrote: 14 Nov 2024, 22:10 I'm upgrading from 519, how come not a word that SSH port automatically changes from 22 to 9222 without warning user !??
It's always been 9222 as far as I have known.
Regards
F2-423
TOS 7.0.0777 (X86)
