TOS 6.0.673 (X86) is Released for Update
ColaChen
Re: TOS 6.0.673 (X86) is Released for Update
Post by ColaChen »
vignatiev wrote: 18 May 2025, 04:15
Thank you for your feedback. Date selection is performed by clicking your desired date, then confirming with the ✔ checkmark button displayed.
vignatiev
Post by vignatiev »
ColaChen wrote: 18 May 2025, 10:49
I’d like to change only date format, not to change date. If select date format and sync with server - NaN.
When select manual with dd.mm.yyyy, I have NaN too.
F4-424
ColaChen
Post by ColaChen »
vignatiev wrote: 18 May 2025, 21:17
Is the result the same regardless of the time zone chosen?
Works fine with GMT. Maybe to do with Language chosen?
vignatiev
Post by vignatiev »
ColaChen wrote: 18 May 2025, 22:20
Yes. I’ve tried several timezones, on each I see NaN. I’ve tried London (+0), Almaty (+6) and Alaska (-9). When I applying date format with dots I see date with selected format less than second, than it become NaN.
F4-424
Alby87
Italy
Post by Alby87 »
Thanks to the support chat, I've discovered you have to do the whole chain of updates, so 648->650-673. I hope this post will help someone too!
sergiot
Austria
Post by sergiot »
I installed this TOS version 6.0.673 on my F4-424 Pro. But all my users are unknown after the reboot.
How do I reinstall the TOS. I installed on the RAID nvme-SSD--disks. It is a pitty such an untested crap is released without
basic testing.
It is also strange I can not reinstall the TOS from the TNAS PC for Windows App.
Can I directly install 6.0.694 then and how to do so?
OrionXie
Saudi Arabia
Post by OrionXie »
sergiot wrote: 06 Jul 2025, 15:50
To upgrade to the next TOS version after 6.0.673, which is 6.0.694, you can follow these methods:
1. Manual update: Control Panel - System - Manual Update.
Download link: https://download3.terra-master.com/TOS% ... 231750.bz2
2. Method b: viewtopic.php?t=423
Installation package download link: https://download3.terra-master.com/TOS% ... 231750.ins
sergiot
Austria
Post by sergiot »
Thank you OrionXie!
I cleaned all disks and ssds and made a new install as all users were missing on the system. I now doubt to use the system
anymore and think to buy another brand. Do not trust the software much. Good it happend now with no data on it.
sergiot wrote: 07 Jul 2025, 02:53
You could try alternative operating system before investing in new hardware, if you feel that way.
