TOS 7.0.0559 Beta (X86) is Released for Update
snapsh0t
Re: TOS 7.0.0559 Beta (X86) is Released for Update
Post by snapsh0t »
Thanks. I've already updated to 7.0.0601 and debug logging is on. If the NAS doesn't start on Saturday morning the logs will be on their way later that day.
svbti
Post by svbti »
rfbjr wrote: 30 Apr 2026, 21:37 System reset did the trick, filemanager is working again.
Good afternoon.
Please tell me how you reset the system settings without losing data.
I'm facing a similar issue after updating to TOS 7.0.0500-00899.
When I try to log in, I receive the error
502 Bad Gateway nginx/1.18.0 (Ubuntu)
The filemanage.service service doesn't start, and sometimes it works but eventually stops again.
rfbjr
Post by rfbjr »
My System disk is on M.2 SSD and the disk array is a separate volume/storage group. Don't think this part matters.
I also did copy some folders (just in case) from my windows machine via SMB.
I just selected reset:
It did change the IP of NIC1, but since I changed all the device names, I always just use the name. Worse case the TNAS PC shows the new IP.
It did reset some regional/display settings.
F6-424 & F4-425 Plus at 7.0.1188
F4-424 Pro (x2) also at 7.0.1188
MikeZhang
Post by MikeZhang »
svbti wrote: 21 May 2026, 15:22
Can you still connect via SSH now? viewtopic.php?f=78&t=2350
If yes, please visit official website online chat for detail troubleshooting.
MikeZhang
Post by MikeZhang »
rfbjr wrote: 21 May 2026, 18:43
You may change it back to previous IP manually on TNAS PC or TOS control panel>network>interface if needed.
rfbjr
Post by rfbjr »
Thanks, but since name resolution works I don't bother. Granted I do look up the IP for the mobile app.
snapsh0t
Post by snapsh0t »
snapsh0t wrote: 20 May 2026, 18:59 Thanks. I've already updated to 7.0.0601 and debug logging is on. If the NAS doesn't start on Saturday morning the logs will be on their way later that day.
NAS started correctly this morning (although the system log time is still an hour early) so I've turned off debug mode..
EriChan
Post by EriChan »
snapsh0t wrote: 23 May 2026, 14:55
Thanks for your feedback on the new progress.
MikeZhang
Post by MikeZhang »
nikk wrote: 02 May 2026, 07:39
This issue was fixed, please update to newer TOS version
viewtopic.php?t=10117
