TOS 7.0.0612 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0601 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank users @crisisacting, @Gremlin, @rfbjr, @EgorA, @AES, @DCCentR, @snapsh0t, @usersky, @MrVanz, @Riccobono67, @mnewland, @B0rg, @robr, @kai, @exqo, @storageninja, @mossholderm and others for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bug Fixes:
1. Fixed an issue where the column sorting function did not work.
2. Fixed an issue where important information was written to the log when joining a domain.
3. Fixed an issue where clicking sort after searching in File Manager cleared the search results.
4. Fixed an issue where the select all and delete operation was invalid when there was only one folder.
5. Fixed an issue where the network interface's connection status updated too slowly.
6. Fixed an issue where some processes were still using the proxy after it was disabled.
7. Fixed an issue where File Manager might show a 502 error if opened immediately after a system update.
8. Fixed an issue where the prompt was incorrect when deleting a folder without permission.
9. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS Mobile 3.5.068 for Android.
6. TNAS Mobile for iOS: https://testflight.apple.com/join/wFWYABJS
Re: TOS 7.0.0612 Beta (X86) is Released for Update
Andy2026 wrote: ↑26 May 2026, 14:09 Image
Thank you for the feedback. Our lab hasn't been able to reproduce it yet. May I ask if you performed any special actions at the time? Also, does refreshing the browser or waiting for a while restore things to normal?
Andy2026
Mexico
Post by Andy2026 »
No.Appeared when reinstalling the system. On a clean system. Still on the previous version. I looked at it on different browsers. This problem is everywhere. Almost everything widgets are duplicated. Maybe an accident. But the problem remained after this update...
Updated the system: TOC6 / TOS_X642.0_Update_7.0.0517_00917_2604091742 / TOS 7.0.0607
MikeZhang
Post by MikeZhang »
Andy2026 wrote: ↑26 May 2026, 15:27
Does clearing browser cache or restarting NAS make any difference?
What's your PC OS version, and what browsers do you use?
dgmigdot
Germany
Post by dgmigdot »
Update from TOS 7.0.0601 beta to TOS 7.0.0612 beta was not possible with the "Languge and Region - Russian". As soon as the locale changed to "English", the update was successful. Other L&R variants were not tested.
dgmigdot
Germany
Post by dgmigdot »
RyanYang wrote: ↑26 May 2026, 15:21
I do not have such issue.
rfbjr
Post by rfbjr »
Interesting way to start my day, got the heart started. I updated the F6-424 first.
Logged on after the update to see this:
Clicked Cancel
Did a reboot, much better.
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
rfbjr
Post by rfbjr »
The F4-424 Pro didn't update. I mean I saw the screen, the usual please wait 5-10 minutes, but if an error message displayed, I didn't see it.
First thing I noticed was the logon screen still showed v601.
Went back to system screen and it looked like nothing happened, I downloaded the update again.
I'm waiting for the raid 5 process to quiet down (since the system did reboot from the first attempt) before I try again.
D4-320 & D4-SSD
Andy2026
Mexico
Post by Andy2026 »
MikeZhang wrote: ↑26 May 2026, 16:23
Restarting the NAS does not solve the problem. Browsers Firefox / Microsoft Edge. Windows 11 26200.8521. I reinstalled the system 2 times with formatting the system SSD disk. And the problem remained. The problem with the widget appears immediately after installing a clean system...
