TOS 6.0.770 (X86) is Released for Update
Re: TOS 6.0.770 (X86) is Released for Update
crisisacting wrote: ↑22 Sep 2025, 14:51 It's currently still a beta release: viewtopic.php?t=7888; TOS 6 for ARM stable release seems to be at least one more beta away.
This version has been very stable during its 5-month beta period, with no significant issues found. You may consider it.
Claus wrote: ↑18 Sep 2025, 22:17
Claus wrote: ↑10 Aug 2025, 22:37 Hallo,
bei eingerichteten Hypercache laufen die Festplatten nach Neustart eine Ewigkeit. Rad5 Prozess !!!
Ohne aktivierten Hypercache ist nach Neustart alles ruhig.
Update: Hypercache gelöscht. Nach 2 Wochen und mehren Neustarts mit gelöschen Hypercache alles ok.
Hypercache nun aktiviert. Die ersten Neustarts (-5) nach Tagen ok
Mein Gefühl: Jetzt wieder nach den 10 Neustart dauert der >Raid 5 immer länger.
Bitte prüfen.
Hypercache läuft im Raid 0 mit WD Red 2x1 TB !!!
It is difficult to believe this may be related to SSD Hyper Cache. No such cases have been observed so far.
If you write or delete a large amount of data before shutting down, this phenomenon may occur when restarting. This is because the BTRFS file system is processing unfinished work from before shutdown, and it is a normal phenomenon.
addx972
France
Post by addx972 »
the automatic switching on of the nas does not work again
TMlinda
Post by TMlinda »
addx972 wrote: ↑26 Sep 2025, 22:41
Are you referring to scheduled startup tasks or the power-on after a power outage feature? Please describe how you reproduce the issue, as well as the device model and system version.
addx972
France
Post by addx972 »
TMlinda wrote: ↑27 Sep 2025, 15:04
yes the schedule startup tasks, I set it to turn on at 6 p.m. every Thursday and it no longer works I changed the time and the day but still not, however to turn off it works I had already had this problem which had been resolved in an old update.
My nas : F4-424, Version : 6.0.783-01200
TMlinda
Post by TMlinda »
addx972 wrote: ↑27 Sep 2025, 15:21
We're currently trying to reproduce this issue in our lab.
You can try restarting your device or updating to TOS version 6.0.783. viewtopic.php?t=9061
