TOS 6.0.770 (X86) is Released for Update
Target Users:
Users currently running TOS 6.0.694 or later versions.
Note:
1. If your TOS version does not meet the requirements, please first check the update conditions for TOS 6.0.530.
2. This update package is applicable to TOS 6 beta version.
3. Due to security fixes for file sharing vulnerabilities, all previously created sharing links will be invalidated after this update. To ensure uninterrupted service, please update your TNAS Mobile and TNAS PC applications.
Here, we sincerely thank user monkeyboy72、Ziptr、rvescovi、rfbjr、OttO1916、spleenrun、s2x3d、mmedic、crisisacting、Nitrokalel、sianderson、Gremlin and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed the issue that the network showed as disconnected after restoring system configuration.
2. Fixed the issue that desktop icons disappeared after a system update.
3. Fixed some issues with the network aggregation feature.
4. Fixed some issues with the Recycle Bin functionality.
5. Fixed some issues with SPC.
What's new:
1. Added system disk migration functionality.
2. Updated system network management tools.
3. Added login verification for accessing certain applications.
4. Updated TNAS.online with faster remote connections and more stable access.
5. Added compatibility for rack-mounted TNAS devices (U12-722 Series Products).
Important Information:
Update Procedure:
Or download the TOS 6.0.770 update package: (md5:bd79da81dcc8a6ff139a700d58ad9326). This update only supports TOS versions from 6.0.530 and above to 6.0.770 and below. Please do not update from other TOS versions.
Other Software Downloads:
Download TNAS PC 5.2.300 for Windows OS:
https://download3.terra-master.com/Apps ... .2.300.exe
Download TNAS PC 5.2.288 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .2.288.pkg
Download TNAS PC 5.2.288 for macOS (ARM architecture):
Download TNAS Mobile 3.4.023 for Android:
https://download2.terra-master.com/TNAS ... .4.023.apk
TNAS Mobile for iOS: Download from the iOS App Store.
Note:
Update Notes
Bugs fixed:
What's new:
Update Procedure:
- FredMutter
Re: TOS 6.0.770 (X86) is Released for Update
the update worked
BUT I found a little error in the TNAS PC for Mac OS ARM version. It says Version 5.1.288 (5.1.288). It should be 5.2.288, correct!?
Model: F2-424 with TOS 7.0.1105 - currently changing every month
- Bios V08
Please go to the settings page in the TNAS PC desktop application to check the version information.FredMutter wrote: ↑06 Aug 2025, 14:25 the update worked
- FredMutter
OK one info is correct the other one is not.TMtina wrote: ↑06 Aug 2025, 15:17Please go to the settings page in the TNAS PC desktop application to check the version information.FredMutter wrote: ↑06 Aug 2025, 14:25 the update worked
As you can see in my screenshot =>
- Bios V08
- sianderson
- Silver Member
Updated my F2-423 to 6.0.770 no problem (although forgot my VM doesnt start automatically) so now dont have remote access to do the F2-424 until i go home haha as the VM provides my VPN
got the notification email to say its been updated though, it would be really nice if we could get the notficiation emails to say there is a new version available, instead of having to randomly check the forum, as it would be more user friendly that way
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Thank you for your feedback!FredMutter wrote: ↑06 Aug 2025, 16:13OK one info is correct the other one is not.TMtina wrote: ↑06 Aug 2025, 15:17Please go to the settings page in the TNAS PC desktop application to check the version information.FredMutter wrote: ↑06 Aug 2025, 14:25 the update worked
We have confirmed that this is an issue with the TNAS PC client, and it will be fixed in an upcoming version update.
- thierrys73
Good morning
My remote connection does not work from the Android mobile application (5g) 3.4.023.
but in local wifi connection, everything is correct
Tnas T6-423
Tnas F2-221
Tnas F2-221
Was the connection okay before updating to version 6.0.770?thierrys73 wrote: ↑06 Aug 2025, 18:03 My remote connection does not work from the Android mobile application (5g) 3.4.023.
Please confirm if the NAS is connected to the internet and check if the TNAS.online service is enabled. (TOS Web - Control Panel - Network)
Try accessing the NAS remotely via a browser.
- FredMutter
My connection doesn't work too
The IP address is solved but the port 5443 is not (even if in the firewall a "all ports are opened" rule exists)
- Bios V08
- FredMutter
using Safari or Chrome => Safari can’t open the page ‘https://192.168.178.111:5443’
(the internet address is resolved but not the access port 5443)
- Bios V08
