TOS 6.0.577 (X86) is Released for Update
CraftyClown
Re: TOS 6.0.577 (X86) is Released for Update
Post by CraftyClown »
brigius wrote: ↑15 Jan 2025, 22:54 I just installed Tos6... fingers crossed and hope it doesn't crash
I have the F4-424 Pro and for the most part it is rock solid. Just be careful if you are attaching an external DAS as there is a power issue resulting in overheated disks
spaceman
United Arab Emirates
Post by spaceman »
TMroy wrote: ↑07 Jan 2025, 00:14
spaceman wrote: ↑06 Jan 2025, 22:51 I can't mount Windows and WD Cloud shares using Remote Folder. I'm geting error remote source path unavailable.
I can easily mount through shell and mount -t cifs
Please refer to the mount example shows on the UI and make sure your information you input is correct.
Attaching 2 screenshots:
1. is when I do the same from terminal and I can mount it successfully
2.t is when trying to mount the folder via GUI (I have proper access to both source and destination folders, password is correct)
I can't mount anything in my network - be it windows machine, WD Cloud, whatever it just always gives the same error.
PS: There was a docker manager update today, after I updated and opened it said docker engine not enabled then chinese letters including the buttons. I enabled it but I lost my containers... This is system is hell and I have 25 years experience in UNIX/Linux system. Many errors are in chinese, logs are in chinese. I'm just a second by returning this unit and getting something else.
The TOS system is not Linux - it is based on Linux. More so now than previously, incidentally, but you still have to understand that you cannot necessarily perform "standard linux functions" as you might expect. If you want 'linux' look at installing an os of your choice. There are several examples of users doing so both here and in other forums. (and, yes, some things are still 'broken' and need to be addressed.)
spaceman
Post by spaceman »
spaceman wrote: ↑18 Jan 2025, 20:08
Ok so today docker engine died again and all my containers disappeared again on restart. That's too much for me. No need to reply, I bought unRaid.
TMtina
Post by TMtina »
The "Mount path" you entered is incorrect. Please enter it according to the mount example displayed on the UI.
We will verify the Docker-related issues you encountered. In addition, Could you provide a screenshot of the page displaying Chinese?
spaceman
Post by spaceman »
it's entered exactly as in example!
CraftyClown
spaceman wrote: ↑20 Jan 2025, 15:57 it's entered exactly as in example!
My guess is they're pointing out the examples use a local IP address rather than the device name?
spaceman
Post by spaceman »
CraftyClown wrote: ↑20 Jan 2025, 17:58
Which I did as well with same results, but it should work with the name as well as it does when mounting in shell.
Re: TOS 6.0.577 (X86) is Released for Update - Remote folders
We went through this, at length, in the following and other posts. I thought it was fixed, but it's not something I use so I don't remember the true outcome. Shame if this is another example of the 'fix' being lost in subsequent renditions of the os.
viewtopic.php?t=5971&hilit=Remote+folder&start=50
(Sorry if it's a long and pointless read, but it is what it is and feelings at the time were "running high").
sae24
Post by sae24 »
[/quote]
From which version?
[/quote]
I've spend a lot of time to find way to update F4-422, now I have 6.0.610 version, all fine.
But I know much easy way to find update for all models, syno use it. On web U may take model and current version - got right way to update and files for download :-)
