TOS 6.0.783 (X86) is Released for Update
Nitrokalel
Mexico
Re: TOS 6.0.783 (X86) is Released for Update
Post by Nitrokalel »
TMzethar wrote: ↑25 Sep 2025, 14:21
gracias
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
jpeckinp
Post by jpeckinp »
Is 6.0.783 going to be last release on version 6? Are we going to ver 7 next?
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
jpeckinp wrote: ↑13 Nov 2025, 10:00 Is 6.0.783 going to be last release on version 6? Are we going to ver 7 next?
TOS 7 is still in the internal testing phase and will be released after the testing is completed.
mmick
Portugal
Post by mmick »
CursaYang wrote: ↑17 Oct 2025, 17:41 In version 6.0.783, if you want the NAS to boot from the newly installed M.2 drive. After installing the M.2 drive, you can directly migrate the system from the HDD to the M.2 drive.
I just installed a M.2 drive (NVMe, 256 GB), I initialized the drive and nothing happened. How do I migrate the OS to the M.2 drive? The migration option does not show the M2...
EDIT: people with several HDDs in (T)RAID, as the system is on all HDDs, we have to select all drives to migrate from and then, it will show the SSD as the destiny to the migration
Now another question: I have the 256 GB SSD with the system, can I use it for something else (still being the system drive?) I wanted to have the SSD as the system drive + cache but now that the SSD has the system, it is greyed out on the cache creation window...
mmick wrote: ↑16 Nov 2025, 22:02
When using an SSD as storage, the system reserves a system partition on the SSD that can be used as the system at any time. However, when used as cache, the entire SSD is required to be formatted and utilized, and no system partition can be reserved for the system.
mmick
Portugal
Post by mmick »
TMzethar wrote: ↑17 Nov 2025, 09:58
Thank you. Can I use the NAS as a dropbox-like decide too? How? The idea is to sync and access from everywhere, not only at home. :mrgreen:
mmick wrote: ↑20 Nov 2025, 01:53 Thank you. Can I use the NAS as a dropbox-like decide too? How? The idea is to sync and access from everywhere, not only at home. :mrgreen:
The TerraSync tool on the TNAS PC (in conjunction with the TerraSync Server app installed on the TOS) can achieve synchronization. If you want to implement remote synchronization, you need to set up your network and open the ports required by TerraSync.
mmick
Portugal
Post by mmick »
TMzethar wrote: ↑20 Nov 2025, 09:43
but does it work with phones like android and ios? The idea is not to pay for Dropbox services and similar. Is there a tutorial?
StephenNaylor
Post by StephenNaylor »
I just added a new drive to my F5-422 to replace an older smaller drive. A few hours later I logged back in and the dashboard said Volume 1 was rebuilding and was at 98.1%. That seemed to be very quick progress so I went into Control Panel > Volume and this shows that the volume is rebuilding but only at 78%. I assume these two displays should show the same figure. I assume the dashboard is wrong. Estimated time is 2500+ minutes:
StephenNaylor wrote: ↑20 Nov 2025, 22:01 I just added a new drive to my F5-422 to replace an older smaller drive. A few hours later I logged back in and the dashboard said Volume 1 was rebuilding and was at 98.1%. That seemed to be very quick progress so I went into Control Panel > Volume and this shows that the volume is rebuilding but only at 78%. I assume these two displays should show the same figure. I assume the dashboard is wrong. Estimated time is 2500+ minutes:
You can enter the following command in the terminal to view the actual progress: cat /proc/mdstat
