We've confirmed this is a bug. Please wait for a future update, which will include a fix for this issue.marethari wrote: ↑05 Jul 2026, 01:23 Updated my Terramaster F4-223 to 7.0.0765 (went from 5->6->7.0747 -> this one). Now I have an issue assigning permissions for an user group for a specific folder. If I'm assigning them from the shared folders, it works, but as soon as I go to the file manager and try to check the permissions from there, the permission for the user group disappears even if I don't do any changes or press apply. If I try to apply the permissions from the file manager, they are not saved. Is this a bug with the new version or is this the expected behavior?
TOS 7.0.0765 Official Release (X86) is Now Available
Re: TOS 7.0.0765 Official Release (X86) is Now Available
Where can I download the upgrade file for 7.0.0765? I want to try a manual upgrade from TOS 6.0.794 as the upgrade to 7.0.747 fails every time I try it on my F4-423.
Regards,
Dave
Regards,
Dave
Your upgrade path from TOS 6.0.794 to TOS 7.0.0747 is correct. Were there any error prompts during the failed upgrade? If your system is currently installed or you plan to install it on an M.2 NVMe SSD, please adjust the BIOS boot order as instructed before updating: viewtopic.php?t=9417
I've updated my T6-423 today, so far I have not yet seen any issues.
My TNAS
- Device = T6-423
- RAM = 32gb official Terramaster ram
- Disks = 3 x Seagate IronWolf ST400VN006 4TB
- TOS = 7.0.1163
- BIOS = 5.19
- Mobile App = 3.5.0.81
After investigation, it has been confirmed that the issue was caused by an anomaly on the server side. The problem has now been resolved. Please try performing the update operation again.
Is the upgrade process still stuck at 92%?
If so, please contact online technical support through the following link for troubleshooting:
It is stuck at 92% ... no changesEriChan wrote: ↑07 Jul 2026, 17:49Is the upgrade process still stuck at 92%?
The link send to a bot with no solution ...
Any solution?
Is there a manual download for this update?
