TOS 7 Is Now Out of Beta — Official Release
xpusostomos
Australia
Re: TOS 7 Is Now Out of Beta — Official Release
Post by xpusostomos »
Every time I login to TOS7 a little message in red at the top of the screen "Failed to retrieve data", and then it disappears. I have no idea what it refers to or what it means. The NAS seems ok as far as I can tell, just that worrying little popup.
EriChan
Post by EriChan »
xpusostomos wrote: ↑06 Jul 2026, 10:10
Thank you for the feedback. We’ve addressed this issue and resolved it in upcoming releases. Please keep an eye on upcoming updates.
Jmb
Post by Jmb »
Phil wrote: ↑06 Jul 2026, 09:49
Jmb wrote: ↑06 Jul 2026, 04:28 I upgraded successfully my F2-223 to TOS7. However I skipped the 'allow system run a permission conversion process' and don't know how to restart it.
Can you help ?
If you skip this step, you will need to manually reconfigure the permissions for your shared folder; the permissions from TOS 6 will not be inherited.
ok ...
Updated F5-221.
This was the last of my Tos6 devices in use (and my principle backup device).
Noted that "unzip" process shows a countdown. After the countdown completed ......nothing! There is a suspiciously long pause which, particularly on a remote device, is unnerving. Then the "update" continues. Perhaps something could be done to indicate background activity between process segments.
Immediately after initial login all drives appeared normal. Allowed the "permissions adjustment" to continue automatically. This completed without apparent issue.
After a couple of minutes I noted that a "corrupted storage pool" appeared. While I was (sort of) expecting this following Beta experiences, I was surprised that it took time to appear. However, knowing the disk layout, I was able to identify this as a rogue report and delete the "corrupted" pool without concern.
System identified 5 apps as needing update and these were performed without issue.
Proceeded to update to latest Tos7.
Renzz
Israel
Post by Renzz »
Is there an official image TOS7 image? i want to manually fresh install it on an NVME.
There is a Tos7 install package available "in the wild", but you can't guarantee that it will give you the correct bootloader package for your model atm. Best to retry an install of latest Tos6 and update following the applicable notes, warnings and procedures for your particular device.
Pretext3890
Netherlands
Post by Pretext3890 »
After updating my F4-424/MADN0101.V08 to TOS7, syslog is flooded by repeating messages even w/o any disks attached (except for the NVME system one)
Jul  7 16:40:35 tnas kernel: [  112.072760] pcieport 0000:00:1c.6: AER: Correctable error message received from 0000:00:1c.6
Jul  7 16:40:35 tnas kernel: [  112.072767] pcieport 0000:00:1c.6: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
Jul  7 16:40:35 tnas kernel: [  112.072769] pcieport 0000:00:1c.6:   device [8086:54be] error status/mask=00000001/00002000
Jul  7 16:40:35 tnas kernel: [  112.072770] pcieport 0000:00:1c.6:    [ 0] RxErr                  (First)
tnas:/# grep -o 'AER' /var/log/syslog | wc -l
13118
tnas:/# uptime
16:55:28 up 2 min,  0 users,  load average: 1.62, 0.99, 0.39
lspci -v -t
-[0000:00]-+-00.0  Intel Corporation Device 4618
           +-02.0  Intel Corporation Device 46d2
           +-14.0  Intel Corporation Device 54ed
           +-14.2  Intel Corporation Device 54ef
           +-16.0  Intel Corporation Device 54e0
           +-17.0  Intel Corporation Device 54d3
           +-1c.0-[01]----00.0  Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
           +-1c.3-[02]----00.0  Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
           +-1c.6-[03]----00.0  ASMedia Technology Inc. ASM1062 Serial ATA Controller
           +-1d.0-[04]----00.0  O2 Micro, Inc. Device 8760
           +-1d.1-[05]--
           +-1f.0  Intel Corporation Device 5482
           +-1f.3  Intel Corporation Device 54c8
           +-1f.4  Intel Corporation Device 54a3
           \-1f.5  Intel Corporation Device 54a4
If I reinstall back TOS6 - there's no such problem/messages.
Please advise.
Renzz
Israel
Post by Renzz »
Gremlin wrote: ↑07 Jul 2026, 18:54 There is a Tos7 install package available "in the wild", but you can't guarantee that it will give you the correct bootloader package for your model atm. Best to retry an install of latest Tos6 and update following the applicable notes, warnings and procedures for your particular device.
Ahh i see.
Well I'll try to reset the system first and if it won't help I'll do as you mentioned.
Thanks.
Ben455
France
Post by Ben455 »
Hello
Do you plan and have a estimated date for an automatic update from version TOS 6.0.0794 ? (not with a manual download & update, on a f4 425)
Thanks 😋
EriChan
Post by EriChan »
Ben455 wrote: ↑08 Jul 2026, 14:31
For compatibility and data security reasons, major cross-generation version upgrades are not supported via automatic updates. Only manual upgrades are available.
