TOS 7.0.0746 Official Release (X86) is Now Available
Re: TOS 7.0.0746 Official Release (X86) is Now Available
Renzz wrote: 24 Jun 2026, 16:15
RyanYang wrote: 24 Jun 2026, 14:43
From 6.0.794.
Wrong update version - you need(ed) 7.0.0747.
MikeZhang
Post by MikeZhang »
Please follow this instruction to upgrade: viewtopic.php?t=10183
MikeZhang
Post by MikeZhang »
Gremlin wrote: 24 Jun 2026, 16:27
Under Backup app>File system snapshot>snapshot list, you will see "Delete" button
JAW
Post by JAW »
RyanYang wrote: 24 Jun 2026, 14:26
JAW wrote: 24 Jun 2026, 00:55
You can update the File Manager from the App Center.
This time I installed the firmware, then started updating all applications.
Unfortunately, I don’t remember exactly what was on the list, but FileManager didn’t seem to be there.
Perhaps you previously updated it manually.
I missed the previous beta update and was waiting for the release.
The latest version was 7.0.0612
ColaChen
Post by ColaChen »
Vanekjin wrote: 24 Jun 2026, 02:25
Could you check what version your Centralized Backup is on? If it isn’t the newest one, please update it before using.
gustang wrote: 23 Jun 2026, 17:58
Our lab investigation found that this issue occurs when the domain group names of LDAP domain users contain uppercase letters. As a temporary workaround, you can either modify the group names, or move the users who need to log in to another group, then leave the domain and rejoin it. We will fix this issue as soon as possible.
Renzz
Israel
Post by Renzz »
MikeZhang wrote: 24 Jun 2026, 16:35
I followed exactly the same guide you linked amd was upgrading from 6.0.794 using the 7.0.747 file.
I eventually rebooted the system and it seems that the update went through and everything seems to be working except Tailscale giving now Bad Gateway 502 error and no longer working. except that i don't experience any issues but i might reset and start from scratch because I'm unable to fix the Tailscale issue after the update.
Renzz wrote: 24 Jun 2026, 19:06
In which case you posted in the wrong thread. Sorry.
Lex
Post by Lex »
First run disk manger show all empty slots.
If switch view or close windows and open again, show is normal
F4-423
JAW wrote: 23 Jun 2026, 19:50
You can open the terminal and run the apt update command, then try the update again. We have found that update failures on some TNAS devices may be caused by interruption of the apt command. You can also click the download button next to the app to get the latest version and install it manually.
The command to enter is as follows:
apt update
