TOS 6.0.794 (X86) is Released for Update
rongie8778
Malaysia
Re: TOS 6.0.794 (X86) is Released for Update
Post by rongie8778 »
the upgrade broke LDAP/DOMAIN group and users sync, please fix! Or is it possible to downgrade to older version which works?!!
Please confirm that there have been no changes to the network and domain server environment configurations before and after the upgrade. Can both the PC and TNAS ping your domain server and resolve it to a normal IP address?
Is there an issue with the on-line download package? I just tried to update F2-221 (from 6.0.770). Package downloaded ok to NAS, but would not update (stalled on unzipping). I then used an earlier version of .694 downloaded to PC and this uploaded to NAS OK, unzipped and was installing. Reported successful, but TNAS reports "Updated to 6.0.770" which is where it started. Going to try another reboot and ..... something .... in the meantime.
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
Third time lucky, I guess.
Checked the update log files and found an "Volume1/.deCompress......." 'not found' and then loads of 'bad key' errors (which sort of made sense). Checked on terminal and could not see any evidence of the missing file(s).
Tried again with the earlier download update file (known good) and it was successful.
TMbuddy
Post by TMbuddy »
Gremlin wrote: 10 Jan 2026, 00:05 Third time lucky, I guess.
Thank you for your feedback. I have reported your issue and the observed phenomenon to our internal team. We will take the abnormal situation you encountered seriously, attempt to reproduce and resolve it. We appreciate your support.
Thanks. I will not be re-visiting this (I hope!) until Tos7 goes live and I update my main nas :)
B0rg
Netherlands
Post by B0rg »
5 months further and no new firmware updates. Terramaster is not updating there TOS with security updates or new feautures :(
Still old docker version is used.
MikeZhang
Post by MikeZhang »
B0rg wrote: 01 May 2026, 10:15
We've rolled out the new TOS7, which includes essential security updates, exciting new features, and an upgraded Docker version. Would you like to give it a try?
sianderson
Post by sianderson »
MikeZhang wrote: 01 May 2026, 16:11
wait what when did it exit beta phase and when was a fully fledged version of TOS 7 released?
or are you suggesting the only way to get "essential security updates" is to use your experimental beta versions of software you are developing? while the production version remains with these "essential security" holes still existing?
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
snapsh0t
Post by snapsh0t »
But your own documentation states that it's not suitable for production use so many users should still be on TOS6 and need to be supported. Dropping support of the release version to concentrate on the next beta is not professional or acceptable.
