TOS 7.0.1278 (x86) Official Release Update
Re: TOS 7.0.1278 (x86) Official Release Update
After the most recent update, I cannot get Plex to open. The port refuses to connect. O have tried uninstalling and reinstalling plex and even going back to an older version that worked and it still doesn't work.
- Crashoveride
EEE off did not fix it.TMroy wrote: ↑01 Oct 2026, 16:43We tested this on TOS 7.0.1278 hardware. Your port isn't failing — it re-links fine at 5G. What's stuck is the data path (the MAC), which doesn't re-arm after your Mac's bus-powered adapter disappears overnight.
The main suspect is EEE (energy-saving Ethernet) at 5G: Realtek's own driver deliberately avoids advertising 5G EEE due to compatibility issues, but TOS ships it enabled.
Note: jumbo frames / MTU 8192 is almost certainly a red herring — a 42-byte ARP can't be affected by MTU, and your Mac captured 0 packets, meaning nothing ever left the NAS.
Please run this and leave it overnight:
Then power the Mac off/on as usual and check in the morning. Please report back:Code: Select all
ethtool --set-eee eth1 eee off
If this fixes it, we'll make the setting persistent.
- Did traffic work without a down/up?
- Output of
ethtool --show-eee eth1- If it still fails, the
output covering the link flapCode: Select all
dmesg
ethtool --set-eee eth1 eee off was applied yesterday and was still disabled this morning. After the Mac was powered off overnight and powered on again, ping 10.10.10.1 from the Mac failed with 100% packet loss. No interface reset was done before the test.
EEE status: disabled
Tx LPI: 13 (us)
Supported EEE link modes: 100baseT/Full 1000baseT/Full 2500baseT/Full 5000baseT/Full
Advertised EEE link modes: Not reported
Link partner advertised EEE link modes: Not reported
ethtool eth1
Speed: 5000Mb/s
Duplex: Full
Link detected: yes
arping -c 3 -I eth1 10.10.10.2
Sent 3 probes (3 broadcast(s))
Received 0 response(s)
[27931.143299] r8169 0000:03:00.0 eth1: Link is Down
[81148.354685] r8169 0000:03:00.0 eth1: Link is Up - 5Gbps/Full - flow control off
[84050.642164] r8169 0000:03:00.0 eth1: Link is Down
[84055.152361] r8169 0000:03:00.0 eth1: Link is Up - 5Gbps/Full - flow control off
[96331.414010] r8169 0000:03:00.0 eth1: Link is Down
[96335.907982] r8169 0000:03:00.0 eth1: Link is Up - 5Gbps/Full - flow control off
[114807.225693] r8169 0000:03:00.0 eth1: Link is Down
[167167.330801] r8169 0000:03:00.0 eth1: Link is Up - 5Gbps/Full - flow control off
TerraMaster F2-425 Plus (Intel N95)
TerraMaster F4-425 Pro (Intel N350)
- Crashoveride
Which drive bays on the F4-425 Pro are wired to the CPU’s native SATA controller, and which are wired to the ASMedia ASM1062?
The bays are numbered 1 to 4 from left to right when looking at the front. The power button is on the right, next to bay 4. Please say which bay numbers are on the CPU SATA ports and which are on the ASM1062.
Looking at the front of the unit (numbered 1 to 4 from left to right):
- Bay 1 & Bay 2: Connected to the CPU's native SATA controller.
- Bay 3 & Bay 4: Connected to the ASMedia controller.
Please perform the following verifications:
1. MTU verification: Change the MTU from 8192 to 1500 to determine whether the issue is related to Jumbo Frame configuration;
2. Link speed verification: Confirm whether the issue occurs only at 5Gbps, and test whether the same problem reproduces at 2500Mbps and 1000Mbps.
- Crashoveride
MTU 1500 did not fix it either.TMjack wrote: ↑03 Oct 2026, 08:18 Please perform the following verifications:
Last night both sides were set to MTU 1500, and EEE on eth1 was still disabled. The Mac was powered off overnight and powered on this morning. No interface reset was done before the test.
ping 10.10.10.1 from the Mac: 100% packet loss.
ifconfig en10
en10: mtu 1500
ip link show eth1
eth1: mtu 1500 state UP
ethtool eth1
Speed: 5000Mb/s
Duplex: Full
Link detected: yes
I can test 1000Mbps next if you still want that comparison.
Just want to ask support if system and app are on the NVME m.2 ssd drive as volume 1 and hdd is volume 2 and is jsut storage not system or app, is it better and less errors?
F4-424
Two D4-320
Two D4-320
If your system drive is on nvme, you don't want to have it on hdd as well. That would be mixing ssd and hdd on raid (raid1) array which is certainly not recommended. The only way to improve might be to have a second nvme to match the one carrying system+Vol1 and have at least the system mirrored (via the system drive migration tool.) Keeping your apps on the nvme is imo a good idea as it means if the apps have activity that does not need data, the hard drives don't need to spin up. (Although that can be hard to avoid if you are using the GUI and the system needs to display usage stats, etc.)
Frustrated Beta Tester!!!
- MacStainless
Is anyone else having issues with TimeMachine completing since this update? My "preparing to back up" statuses last a REALLY long time and backups keep failing after a while with little-to-no data getting copied over.
- Argonautica
Just initiated a manual triggered backup to check:MacStainless wrote: ↑06 Oct 2026, 04:08 Is anyone else having issues with TimeMachine completing since this update? My "preparing to back up" statuses last a REALLY long time and backups keep failing after a while with little-to-no data getting copied over.
"preparing" phase took about five minutes, and the copy was done in about 10 minutes (data copied was only about 18 GB)
"cleaning up" phase took another few minutes.
macOS Sequoia 15.8.1 and TOS 7.0.1278,
Time Machine config was newly setup on TOS 7, and not upgraded from earlier TOS versions.
What OS are you running, and did you upgrade from TOS 6 or earlier? It might help to setup another user on macOS and test a clean config.
If that works, you can try the same thing for your main account.
