TOS 7.0.0765 Official Release (X86) is Now Available
EriChan
Re: TOS 7.0.0765 Official Release (X86) is Now Available
Post by EriChan »
joergurmel wrote: 03 Jul 2026, 00:39
We need to check this issue remotely. Please contact the online technical support staff through the following link to schedule remote technical support:
EriChan
Post by EriChan »
Metrogeek wrote: 03 Jul 2026, 00:45
Thanks for the feedback! We’re already aware of this issue, and it’s on our list to be fixed in a future version. Please stay tuned for the future release.
EriChan
Post by EriChan »
hellotonothing wrote: 03 Jul 2026, 07:02
To more effectively identify the root cause of the problem, we recommend that you contact our online technical support staff through the following link. We will guide you through troubleshooting steps to help resolve the related issues.
AlexNo
Post by AlexNo »
Metrogeek wrote: 03 Jul 2026, 00:45 Terramaster f4-425 plus on latest TOS.
Sometime, when i want to open docker manager it brings me to the app center because the app is disable, so i click enable... It takes a few minutes to make it enable. However, my docker stack working even if it's show disable... I tried to uninstall and re-install docker manager and get same issue. No errors show in the docker manager logs. Should i delete all my config and rebuild my stacks? Anyone else?
Yes, I have the same situation. It's only after the third click on the icon that I see the Docker Manager itself
F4-424 Pro: 32GB RAM | BIOS: MADN0101.V07 | TOS v 7.0.0777
sianderson
Post by sianderson »
GevinKe wrote: 02 Jul 2026, 09:34
sianderson wrote: 01 Jul 2026, 21:02
Thank you very much for your suggestion. We will reevaluate this. Currently, when a new TOS version is available, you will receive a desktop notification immediately after logging in to TOS.
Regarding whether email notifications should be enabled by default, users have different needs—some may find them convenient, while others may consider them disruptive. Therefore, we prefer to give users the choice.
In addition, our current strategy is that for situations with potential risks, TOS will enable both desktop notifications and email notifications by default. For regular operations or situations that do not cause serious consequences, only desktop notifications will be enabled by default.
i appreciate you get a notification if you log in, however a NAS should not require someone to log into it !!!!, it sits locked away in a cabinet / server room and the data is remotely accessed via SMB shares etc, i really don’t understand why you think people should be logging in to the desktop of a NAS drive just to check if there is a software update?
"our current strategy is that for situations with potential risks, TOS will enable both desktop notifications and email notifications by default."
so you don’t class releasing updates fixing security bugs as situations with potential risks? or are you telling us that if we have the option to not ticked to email, you are going to ignore this if the software update contains a bug fix that closes a security hole that puts the user at risk?
as it seems like your current strategy is allowing users to have potential risks without realising it as you are NOT telling people they have updates in places that they would see them by default
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
sianderson wrote: 03 Jul 2026, 23:13
Thank you for sharing your valuable feedback and perspective. Our product team will take another look at this request.
joergurmel
Germany
Post by joergurmel »
Ich hatte wie gesagt schon Kontakt zu diesem Support, aber eine Onlinehilfe wurde mir da nicht angeboten. Werde mich kommende Woche noch mal dort melden! Erst mal Danke!
MFG Jörg
EriChan wrote: 03 Jul 2026, 16:38
ambul
Post by ambul »
Hello! Should I update the motherboard firmware (MADN0301.V02) to v07 on my F8 SSD Plus, given that I’ve successfully flashed it with TOS 7.0.0765 without any issues? Everything is working fine, and I haven’t noticed any problems so far.
F8 SSD Plus MADN0301. V02 TOS 7.0.0765
TMjack
Post by TMjack »
To upgrade the F8 SSD to TOS 7, the ASM2806 chip firmware must be updated to the latest version simultaneously. Based on the screenshot you provided, the current firmware is already the latest, so no further upgrade is required.
The operation of TOS 7 is not related to the BIOS of the F8 SSD device, so there is no need to update the BIOS to the V07 version.
ambul
Post by ambul »
TMjack wrote: 04 Jul 2026, 17:21 so no further upgrade is required.
Thank you so much, I'm very happy, you're the best! :D
