TOS 7.0.0559 Beta (X86) is Released for Update
rfbjr
Re: TOS 7.0.0559 Beta (X86) is Released for Update
Post by rfbjr »
TMzethar wrote: 01 May 2026, 00:16
TMzethar wrote: 30 Apr 2026, 08:55
rfbjr wrote: 29 Apr 2026, 22:14 I see duplicate notifications/emails for rsync jobs.These happen to be recurring ones, if that matters.
Also I happen to notice new notification options for various apps, under control panel/notifications. While all the new options are turned on by default for each, the email isn't. Just more of an FYI.
Recorded, will verify the issue.
We are currently unable to reproduce the situation of the 'double notification' you mentioned
Perhaps it was caused by some special operation If you have any discoveries, please feel free to raise them
Ok with this, I'll see where the rsync notifications fall under which category and turn them off. I see setting under "Backup" as well as a separate section for "Duple Backup". Also this is happening not on the F4-424 Pro but on the F4-425 Plus. :)
I will do some trial and error with the notifications settings.
F4-424 Pro also at 7.0.0777
D4-320
rfbjr
Post by rfbjr »
TMzethar wrote: 01 May 2026, 00:05
rfbjr wrote: 29 Apr 2026, 18:13 Image
Here is the postg modules, no clue why .1 or even it wants .2
If this issue occurs multiple times, you may consider checking the M.2 SSD or contacting the sales team to replace it with a new NAS, and sending this NAS back to us for research
Removed the SSD's completely. Physically out of the device. System disk is HDD#1.
PCIE correctable errors still flooding syslog.
D4-320
samius
Post by samius »
The question concerns the entire 7th branch... Previously, on version 6, if I accessed us through Nginx, everything was fine, but on version 7, some apps, like the app store or file manager, won't open through Nginx. How can I fix this?
And the login page is still hard to read in dark theme, it would be better to return it to how it was 2 releases ago.
F4-424 MAX TOS 7
rfbjr wrote: 01 May 2026, 01:35 Removed the SSD's completely. Physically out of the device. System disk is HDD#1.
We will arrange for a sales specialist to contact you. :)
samius wrote: 01 May 2026, 05:06 The question concerns the entire 7th branch... Previously, on version 6, if I accessed us through Nginx, everything was fine, but on version 7, some apps, like the app store or file manager, won't open through Nginx. How can I fix this?
It seems that you accessed the TOS webpage remotely through TNAS.online, which may be due to low speed We suggest that you achieve remote connection through TNAS PC and then remotely access the TOS webpage through virtual IP Additionally, you can compare the performance when accessing with LAN IP to determine if it is a network connection issue
We have noticed the issue of unclear display of the dark gray login window that you mentioned. Please wait for future version updates
samius
Post by samius »
TMzethar wrote: 01 May 2026, 06:13
I don't use Tnas.online. I use my own Nginx server. And on TOS 6, everything was fine (if I proxy the websocket). On TOS 7, the applications page, file manager, and storage manager aren't visible thrue nginx.
F4-424 MAX TOS 7
rfbjr
Post by rfbjr »
Felix wrote: 30 Apr 2026, 14:29
In the TOS 7.0.0448 Beta update, we modified the system notification trigger rules and changed them to the default. You will need to manually customize these settings.
See the second warning in this update announcement for details.
viewtopic.php?t=9872
Okay you are going to love this:
Turned off the email notification for backup start and completion. Manually ran the recurring rsync. Only received one notification for backup start and completion. Cool.
Turned on the email notification back on, and let the recurring job run, it did just before. Now I get FOUR notifications and emails, each for start and end. Okay, turned email notification back off, next recurring job just ended. I get FOUR notifications for start and stop, no emails obviously.
I have another recurring going to stat in 10min. This time I might leave email notify on and turn off notification and see what happens.
**I will also create a new recurring task, maybe something with the recurring tasks existing before the 559 release applied? Stay tuned.....
BINGO! A new task created after 559 was installed, notifications and email notifications work correctly! One each for start and end.
D4-320
luismartin
Post by luismartin »
TMzethar wrote: 30 Apr 2026, 09:08
luismartin wrote: 30 Apr 2026, 04:16 I have 12 disks in RAID 5 (200TB) and a couple of days ago I installed a 1TB M.2 as a balanced hypercache.
When I boot the enclosure, disk and hypercache activity reading and writing is frantic for almost 3 hours.
Is this a normal behavior how is working hypercache?
Naturally, I've disabled hypercache while awaiting your response.
Based on the existing information, we are currently unable to guess the reason You can consider observing the DiskIO read and write status of processes and devices through the following commands on the terminal:
pidstat -d 3
iostat 3
Is there any documentation that explains how the Terramaster hypercache works?
I've used other caches on other NAS devices and I've never experienced this 3-hour period of activity disk everytime when booting up a NAS because I have activated an M.2 hypercache.
The M.2 capacity is 1TB and the enclosure has 16GB of memory RAM.
rfbjr
Post by rfbjr »
D4-320
nikk
Post by nikk »
The text with the description under the indicators didn't fit. Tried different zooms - all same.
This is also present in previous versions
Control Panel -> Device Monitoring -> Overview
MacOS M1 26.3.1 Safari Version 26.3.1
