TOS 7.0.0448 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @snapsh0t, @Gremlin, @jpeckinp, @rfbjr, @Joesh, @bartmans99, @danx, @OttO1916 and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where some applications could not be uninstalled via the navigation bar.
2. Fixed an issue where unmounted virtual disk directories could be selected when choosing an rsync directory.
3. Fixed an issue where modifying the IP might cause TNAS.online to fail to automatically reconnect.
4. Fixed an issue where some pop-up prompts displayed empty content.
5. Fixed an issue where the firewall could not be disabled.
6. Fixed an issue where an incorrect prompt appeared when editing permissions for a shared folder that has used up its quota.
7. Fixed an issue where the USB capacity usage threshold notification could not be set properly.
8. Fixed an issue where newly authorized directories for Time Machine did not take effect immediately.
9. Fixed an issue where switching to an LDAP domain after joining an AD domain did not provide any prompt.
10. Fixed other known issues.
11. Optimized the display of some pages in the App Center.
Warning:
1. If the first update prompts a decompression failure, please click update again.
2. To reduce interruptions caused by system notifications, we have readjusted the triggering rules for notifications at various levels and simultaneously modified the default system notification settings. After the update, you will need to reconfigure your personal notification preferences.
3. In the current version, the auto-mount function for USBCopy devices is temporarily unavailable. To ensure the normal use of this feature, please refrain from updating to this version for now and wait until the next version is released and the issue is resolved before upgrading.
4. Due to the kernel architecture upgrade in TOS 7, the VirtualBox application will no longer be compatible with subsequent versions and will be removed from the App Center.
We recommend that users who still rely on this feature migrate their existing virtual machines to the officially supported VMs (Virtual Machines) application to ensure continued functionality.
For migration instructions, please refer to the technical documentation: https://toshelp.terra-master.com/faq/category/vms
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.520 for Windows OS.
2. Download TNAS PC 5.2.520 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.520 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
snapsh0t
Re: TOS 7.0.0448 Beta (X86) is Released for Update
Post by snapsh0t »
Is the Windows client download version correct? It's 5.2.506 and I already have 5.2.510 and 5.2.520 downloaded.
In Control Panel/Media Index there is a Last Run date even though media indexing is disabled. I think it would be better if this showed the same --- as Status even if it's only a cosmetic change.
F2-425 Plus updated successfully.
Phil
Post by Phil »
snapsh0t wrote: 17 Mar 2026, 16:48 Is the Windows client download version correct? It's 5.2.506 and I already have 5.2.510 and 5.2.520 downloaded.
Thank you for your feedback. The download link has been updated.
We have noted your suggestion regarding the display of the "Last Run Date" status in "Control Panel/Media Index" and will forward it to the product team. We will consider optimizing it after evaluation.
F2-221 updated with no apparent problems
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
samius
Post by samius »
For me -virtualBox regression. None of the machines will start. The error is as follows:
Exception Object
    [message:protected] => The virtual machine 'Guacamole' has terminated unexpectedly during startup with exit code 1 (0x1)
    [string:Exception:private] =>
    [code:protected] => 0
    [file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
    [line:protected] => 3272
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
                    [line] => 952
                    [function] => remote_machineSetState
                    [class] => vboxconnector
                    [type] => ->
            [1] => Array
                    [file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
                    [line] => 316
                    [function] => __call
                    [type] => ->
    [previous:Exception:private] =>
F4-424 MAX TOS 7
rfbjr
Post by rfbjr »
All three updated, well the F4-424 Pro needed a push, after the update reboot, the webgui showed update in progress. The HDMI console showed the SQL service didn't start and numerous messages about journald not starting. Couldn't putty in. Hard power off/on. System came up fine, no other issues. Other testing to follow tomorrow.
F6-424 & F4-425 Plus at 7.0.1188
F4-424 Pro (x2) also at 7.0.1188
samius wrote: 18 Mar 2026, 00:36
Due to the kernel architecture update in TOS 7, the VirtualBox application will no longer be compatible with subsequent versions and will be removed from the App Center.
You can visit the online chat on our official website to inquire about installing the previous version of TOS 7, export the virtual machines, and then import them into VMs.
For migration instructions, please refer to the technical documentation: https://toshelp.terra-master.com/faq/TO ... Box-to-VMs
rfbjr
Post by rfbjr »
Just noticed on all three of my devices (I'm tired of saying NAS(s), NAS's ;) )
After applying v448
The email notification settings for the warning and information in all categories were turned off. Is this something new or a mistake?
Before I had every category set to notify for notification and email.
samius
Post by samius »
RyanYang wrote: 18 Mar 2026, 15:01 For migration instructions, please refer to the technical documentation: https://toshelp.terra-master.com/faq/TO ... Box-to-VMs
File not found
F4-424 MAX TOS 7
rfbjr
Post by rfbjr »
Another thing :)
With the usual email announcement of the next release could you do something like indicated (**)
I never remember what the current version is I have installed, I usually just launch it on my PC, and it tells me to download a new update.
Client Downloads:
1. **Download TNAS PC 5.2.520 for Windows OS.
