How to Resolve the Issue of F8 SSD Failing to Boot or Automatically Restarting After Installing a 3rd Party OS or TOS7
About TNAS hardware
mstang1988
Re: How to Resolve the Issue of F8 SSD Failing to Boot or Automatically Restarting After Installing a 3rd Party OS or TO
Post by mstang1988 »
I too am running into this issue. I have 6 Samsung 980 Pro 2TB and 2 P3 Plus 1TB drives. The 2 P3 Plus drives populate slots 1 and 2 and the other drives populate slots 3-8.
I was running truenas scale latest and I am at the latest firmware and bios versions or TOS 6. It still crashes. I have VT-D turned off in the bios. Today I removed slots 1 and 2 - will see if we have stability with TOS 6.
Any guidance for those of us that continue to have crashes?
@terramaster:/Volume1/public# ./218xfwdl /s
Asmedia PCIe Gen3 Switch SPI ROM Update Linux Utility - Version 1.7.4.0
Found 1 Asmedia PCIe Gen3 Switch Upstream Port
[04:00.0] PCIe Switch 0: 24 08 21 40 00 00
EriChan
Post by EriChan »
mstang1988 wrote: ↑21 Sep 2026, 04:43
Thank you for sharing the detailed drive configuration and PCIe switch info. To help us accurately investigate what triggers the crash under TOS 6, could you please help collect the diagnostic and debug logs for our team?
Here are the steps to follow:
1. Enable Debug Mode & Generate System Report
  • Go to TOS Web UI > Technical Support (Support & Help) > Issue Feedback.
  • Generate and download the System Report, and make sure to check/enable Debug Mode.
2. Capture Logs When the Issue Occurs
Once the crash/reboot issue reoccurs:
1. Restart the device first.
2. Return to the same menu to download the Debug Logs.
3. Send both the Debug Logs and the System Report to our technical support email: support(at)terra-master.com.
Note the Timestamp: If possible, please note the date and approximate time when the crash happened. Having the exact timestamp will greatly assist our engineers in locating the corresponding events in the logs.
3. Note Regarding Browser Downloads
  • The Debug log package consists of three files: kern.log, syslog, and atop_log.
  • Due to these file extensions/formats, some web browsers may flag or block them. If you find any of these files missing after downloading, please check your browser's download manager/history to unblock, allow, and keep the download.
Once our engineers receive your logs, we will analyze them and provide you with a solution. Thank you for your cooperation!
Return to “Hardware”
