How to Properly Install and Use TOS 7 on the 424 Series TNAS
acayon
Spain
Re: How to Properly Install and Use TOS 7 on the 424 Series TNAS
Post by acayon »
Thanks very much. I will try to install.
Podrez
Moldova
Post by Podrez »
MikeZhang wrote: ↑26 Jun 2026, 18:01
yep) but i needed to reset the NAS and start from the scratch (
OlRedRooster
Post by OlRedRooster »
I want to upgrade my F4-424 Pro's BIOS from V05 to V08 before I install TOS7. The instructions say to "remove all drives" before performing the BIOS update. I have 4 SATA drives with all my data(TRAID Volume 2), my OS installed on an NVME(Volume 1), and I also have a cache NVME. Do you recommend removing just my data drives before performing the BIOS update, or should I also remove both NVMEs as well?
OlRedRooster wrote: ↑01 Jul 2026, 01:06
You don't need to update your bios and, from what I can determine, you won't see any practical benefit. It is more of a nuisance as you should remove all of your drives - basically to avoid the nas booting into the wrong device wile performing the update. And, if you do go ahead take particular note of step 7. A couple of us seem to have got hung up on that step.
Frustrated Beta Tester!!!
EriChan
Post by EriChan »
Your BIOS version does not require any additional adjustments to update and run TOS7 normally.
FredMutter
France
Post by FredMutter »
OlRedRooster wrote: ↑01 Jul 2026, 01:06 I want to upgrade my F4-424 Pro's BIOS from V05 to V08 before I install TOS7. The instructions say to "remove all drives" before performing the BIOS update. I have 4 SATA drives with all my data(TRAID Volume 2), my OS installed on an NVME(Volume 1), and I also have a cache NVME. Do you recommend removing just my data drives before performing the BIOS update, or should I also remove both NVMEs as well?
1) You don't need it
2) I didn't need it too but I've made it :-) without removing my two NVMes => no problem
justanotheraccount
Post by justanotheraccount »
Is there an issue list of what is fixed and addressed from MADN0101.V05 to MADN0101.V08?
I am trying to resolve an issue and don't want to update unless my issue is specified.
Any issues and cause is addressed in post 1 of this thread. If that is your issue then take note. If that does not cover your issue, explain in a separate thread for assistance.
erikcsellers
Post by erikcsellers »
I get it that this discussion is not about a changelog for the bios updates but just to put it to rest, please post a changelog on the bios updates so people will know how important or not important it is to update from v5 to v8 for example even though its not needed to get to TOS7. Or at the very least, link it where people can get this answer.
OlRedRooster
erikcsellers wrote: ↑02 Jul 2026, 22:28 I get it that this discussion is not about a changelog for the bios updates but just to put it to rest, please post a changelog on the bios updates so people will know how important or not important it is to update from v5 to v8 for example even though its not needed to get to TOS7. Or at the very least, link it where people can get this answer.
Agreed, would be nice to know if we're missing important BIOS security updates or not.
I'm staying on V05 for now, the upgrade to TOS7 went perfectly.
