[ Jellyfin ] The Free Software Media System
SWADED
Netherlands
Re: [ Jellyfin ] The Free Software Media System
Post by SWADED »
When using the Jellyfin app from the app center, do I still need ffmpeg? And do I need ModBase? And which driver for terramaster 424 pro, iHD?
I've tried with and without ffmpeg, some items give a fatal playback error. please help me out.
[matroska,webm @ 0x563d0cf0b0c0] sub2video: using 720x480 canvas
Impossible to convert between the formats supported by the filter 'Parsed_scale_vaapi_3' and the filter 'auto_scaler_0'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
[aac @ 0x563d0cfc4700] Qavg: 65536.000
[aac @ 0x563d0cfc4700] 2 frames left in the queue on closing
Conversion failed!
[matroska,webm @ 0x564db42491c0] sub2video: using 1920x1080 canvas
[libopus @ 0x564db4342480] 1 frames left in the queue on closing
Conversion failed!
F4-424 Pro, TOS 6.0.694
For TOS6, ffmpeg51 (and his dependency ffmpeg + ModBase1) is not required as from 10.10.3.3.
SWADED
Netherlands
Post by SWADED »
Thanks and this?
Stream mapping:
  Stream #0:0 (hevc) -> setparams (graph 0)
  Stream #0:5 (dvdsub) -> scale (graph 0)
  hwupload (graph 0) -> Stream #0:0 (h264_vaapi)
  Stream #0:1 -> #0:1 (aac (native) -> aac (native))
Press [q] to stop, [?] for help
[matroska,webm @ 0x55aca0f1e0c0] sub2video: using 720x480 canvas
[aac @ 0x55aca0fd7700] Qavg: 65536.000
[aac @ 0x55aca0fd7700] 2 frames left in the queue on closing
Conversion failed!
m00ndogg
Post by m00ndogg »
outkastm wrote: 22 Dec 2024, 06:07done
Thank you very much!
I have TOS 5.1, should I be using ffmpeg or ffmpeg51?
I updated to Jellyfin 10.10.3.0, but it keeps stopping every time I try to access from my Fire TV, Roku TV or even a web browser.
I restart but it just stops again.
Auto start is enabled but it never does.
Maybe I'll try 10.10.2.0?
Any advice?
gridmonkey
Post by gridmonkey »
TOS 6.0.610
F4-423
I accidently installed JellyFin from the app center to my hdd pool/volume, did all the configuration, and got my libraries all setup, then realized i had wanted to install it to my ssd pool/volume. I know i can uninstall and reinstall to the ssd but is there a way to easily copy configs? I don't see any files in the jellyfin folder on the hdd pool/volume. Thanks
SWADED
Netherlands
Post by SWADED »
Jellyfin server crashes every time I clean the cache.
gridmonkey wrote: 23 Feb 2025, 11:54 TOS 6.0.610
F4-423
Jellyfin store the config and database in the home folder of your superuser account /home/yoursuperuser/MOD_CONFIG/Jellyfin
You can reinstall Jellyfin on the volume you want, config will be reused.
coolnest
Vietnam
Post by coolnest »
It seems that Jellyfin also appears in the official app store. Is it recommended to still install the community version? Thanks
By installing from the official app store, you will receive official support from TM. Usually i will not work on apps that are available in the official app store (with some exceptions). But everyone is free to choose, i will still provide a few versions update and see how it goes.
coolnest
Vietnam
Post by coolnest »
Thanks for the work!
I can't seem to turn on QSV with tone mapping. After enabling tone mapping (either w or w/o vpp), I got fatal playback error.
I am using F4-423 with 6.0.650
Jellyfin 10.10.5.0
ffmpeg version 7.0.2-Jellyfin Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 14.2.0 (crosstool-NG 1.26.0.120_4d36f27)
  configuration: --prefix=/ffbuild/prefix --pkg-config=pkg-config --pkg-config-flags=--static --cross-prefix=x86_64-ffbuild-linux-gnu- --arch=x86_64 --target-os=linux --extra-version=Jellyfin --extra-cflags= --extra-cxxflags= --extra-ldflags= --extra-ldexeflags=-pie --extra-libs=-ldl --enable-gpl --enable-version3 --disable-ffplay --disable-debug --disable-doc --disable-ptx-compression --disable-sdl2 --disable-libxcb --disable-xlib --enable-lto=auto --enable-iconv --enable-zlib --enable-libfreetype --enable-libfribidi --enable-gmp --enable-libxml2 --enable-openssl --enable-lzma --enable-fontconfig --enable-libharfbuzz --enable-libvorbis --enable-opencl --enable-amf --enable-chromaprint --enable-libdav1d --enable-libfdk-aac --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpl --enable-libvpx --enable-libwebp --enable-libopenmpt --disable-rkmpp --disable-rkrga --enable-libsrt --enable-libsvtav1 --enable-libdrm --enable-vaapi --enable-vulkan --enable-libshaderc --enable-libplacebo --enable-libx264 --enable-libx265 --enable-libzimg --enable-libzvbi
  libavutil      59.  8.100 / 59.  8.100
  libavcodec     61.  3.100 / 61.  3.100
  libavformat    61.  1.100 / 61.  1.100
  libavdevice    61.  1.100 / 61.  1.100
  libavfilter    10.  1.100 / 10.  1.100
  libswscale      8.  1.100 /  8.  1.100
  libswresample   5.  1.100 /  5.  1.100
  libpostproc    58.  1.100 / 58.  1.100
libva info: VA-API version 1.16.0
libva info: Trying to open /usr/local/ModBase1/sys/lib/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_16
libva info: va_openDriver() returns 0
[AVHWDeviceContext @ 0x560ce0bfdbc0] Failed to get number of OpenCL platforms: -1001.
Device creation failed: -19.
Failed to set value 'opencl=ocl@va' for option 'init_hw_device': No such device
Error parsing global options: No such device
