[ Jellyfin ] The Free Software Media System
About : https://jellyfin.org/
Applicable TOS5: 5.0.130 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/jellyfin
Required packages:
ffmpeg51 for TOS5
About
Free media server with hardware transcoding enabled
Jellyfin is a Free Software Media System that puts you in control of managing and streaming your media. It is an alternative to the proprietary Emby and Plex, to provide media from a dedicated server to end-user devices via multiple apps. Jellyfin is descended from Emby's 3.5.2 release and ported to the .NET Core framework to enable full cross-platform support. There are no strings attached, no premium licenses or features, and no hidden agendas: just a team who want to build something better and work together to achieve it.
Re: [ Jellyfin ][ 10.7.1.0 ] The Free Software Media System
Added 10.7.1.0
RadicalDave
Post by RadicalDave »
What's the best way to get 10.7.5 version?
working on the update
Re: [ Jellyfin ][ 10.7.5.0 ] The Free Software Media System
updated to 10.7.5.0
sapstar
Post by sapstar »
Hi, is there a version of Jellyfin that works on F2-210? I tried the docker image, it installs fine, but I am unable to reach the interface on the default 8096 port once installed.
Mnemosys85
Post by Mnemosys85 »
Hi, I found this guide on the internet that worked for me. I installed Docker from 'Applications' section and followed the next steps.
(The images are in Chinese but are very intuitive.)
Jellyfin is a media server software that manages and plays streaming media files on multiple platforms.
1. The registry searches for Jellyfin and downloads the image;
2. After the download is complete, enter the image interface, select the downloaded image and click to start;
3. Set the container name;
On this step, you can set how many resources you want to allocate for this container.
4. Set the folder and load path in the volume interface (folders need to be created in advance);
5. Set the port (local port can be customized, as long as it does not conflict with other ports.)
6. Click Apply after the setup is complete.
7. Go to the container interface to view the Jellyfin image you just set.
8. After setting up the docker image, you can access the media server through the webpage. The access address is the local port (IP+docker container).
betuning
Post by betuning »
Good job
but there is a problem with the identify function, plug-in, it does not return anything.
While with the Docker version these functions work.
But I prefer your version for the Hardware acceleration
I'll have a look for plugin issue on the next update
