TOS 7.0.0392 Beta (X86) is Released for Update
samius
Re: TOS 7.0.0392 Beta (X86) is Released for Update
Post by samius »
TMzethar wrote: ↑22 Jan 2026, 23:23
i cant upload screenshots to postimages (
ya.disk:
https://disk.yandex.ru/i/3wd5I2RW8PCt9g
https://disk.yandex.ru/i/hwRRbA8pUUZWgQ
F4-424 MAX TOS 7
Aritoc wrote: ↑23 Jan 2026, 04:25
Second incident it seems. >> viewtopic.php?p=53669#p53669
Aritoc wrote: ↑23 Jan 2026, 04:25 Hello! I'm having problems updating from 7.0.0299. I'm getting the message "Update check failed. Please check your network connection and try again.". The NAS has an internet connection and everything else is working as intended.
Sorry for the trouble.
We have observed multiple instances of this issue. The project team has started troubleshooting. The initial guess is that it may be due to a poor server connection.
Trying a few more times might work. If it still doesn't, you can download the update package directly using the link. (The 7.0.0392.bz2 link has been sent to you via private message on the forum)
urb4n
Post by urb4n »
Good afternoon! Can I also get a link to download TOS 7.0.0392 Beta, as I am also unable to update from the system. The same error occurs...
ColaChen
Post by ColaChen »
urb4n wrote: ↑23 Jan 2026, 18:43
Please try switching to another system language and check again.(The 7.0.0392.bz2 link has been sent to you via private message on the forum)
TMjack
Post by TMjack »
Could you please try downloading the TOS 7.0.0392 upgrade package through the following link to confirm if it can be successfully downloaded? At the same time, we will conduct a thorough check of the server and perform an in-depth analysis to identify the cause of the issue.
https://download3.terra-master.com/TOS% ... 161550.bz2
TMjack wrote: ↑24 Jan 2026, 11:28
Manual download via Browser (Firefox) is OK.
Nibenor
Germany
Post by Nibenor »
Can also confirm, manual download via Safari is ok.
I noticed that in Control Panel => Hardware & Power => Disk Sleep gets reset to the default of 10 minutes on each update/upgrade. It would be nice if a custom setting could be retained to better protect the hard drives. I have set it to 1 hour.
On a side note: I really liked the default wallpaper in TOS 6 (the lynx), but I forgot to save it. Could I still get this image somewhere?
F2-424 TOS 7.0.0392 • 2x Lexar NM790 4 TB (Single Disk, ext4) • 1x WDC EDBZ 12 TB (Single Disk, ext4)
System add-ons: less, nano, mc • Nginx include: SSL reverse proxy config
Containers (upstream): Technitium DNS, MediaWiki, Jellyfin, Immich
ColaChen
Post by ColaChen »
Nibenor wrote: ↑24 Jan 2026, 20:44
Regarding the hard drive sleep mode issue, this is a known issue and will be fixed in a subsequent version.
urb4n
Post by urb4n »
Good afternoon! After updating the system, I cannot access the device via the web using your link... SSH only. I tried to clean the etc/p directory, but I don't have it. How can I restore access?
