Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank user @Gremlin,@rfbjr,@DCCentR,@PeteBest,@f2245Plus,@OttO1916,@True1Santony and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where uninstalling USB Copy might delete system notification files.
2. Fixed an issue where entering the developer mode page for the first time could trigger an error.
3. Fixed an issue where sorting installed applications by update time was incorrect.
4. Fixed an issue where the cancel function might fail during manual upload of application installation packages.
5. Fixed an issue where repeatedly selecting different DDNS servers might result in no data being displayed.
6. Fixed an issue where desktop shortcuts copied to other locations could not be properly deleted.
7. Fixed an issue where the pop-up styles were inconsistent across some pages.
8. Optimized the style of table statuses in Storage Manager.
9. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.506 for Windows OS.
2. Download TNAS PC 5.2.506 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.506 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
TOS 7.0.0392 Beta (X86) is Released for Update
Re: TOS 7.0.0392 Beta (X86) is Released for Update
Installed, working well.
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
1 X 2TB (SSD) Hyper Cache
Technical Summary: Connectivity Issues on TOS 7 Beta with Bonded Interfaces and Tailscale
1. Environment Configuration
Hardware: TerraMaster NAS (X86 Platform)
OS: TOS 7 Beta (Build .0392)
Network Setup: * Bonding: Bond 1 (Balance-XOR) with a mix of 2.5GbE and 1GbE links.
Hash Policy: Layer 3+4 (IP + Port).
Docker: Using Macvlan for containers (Pi-hole, Tailscale).
Internal IP: 193.178.22.90
2. Problem Statement
After upgrading to TOS 7 Beta and configuring Link Aggregation (Bond 1), the NAS is accessible via local IP but fails to respond to external/remote requests via Tailscale and DDNS, even though the NAS can be "Pinged."
3. Key Issues Identified
Asymmetric Routing & Packet Reordering: Because the bond consists of mismatched speeds (2.5G + 1G), the Balance-XOR (Layer 3+4) policy causes packets to be sent out across different interfaces. This leads to out-of-order packets and MAC address switching, which causes Tailscale and remote HTTPS connections to drop or "Time Out."
Strict Host Header Validation (Application Layer): TOS 7's web server (Nginx) appears to have stricter security. When accessing the NAS via Tailscale IP (100.x.x.x) on port 5443, the server returns "Connection Refused." This suggests the OS is rejecting requests that do not match the local hostname or local IP whitelist.
Macvlan & Host-to-Guest Conflict: Running Tailscale/Pi-hole inside a Docker Macvlan prevents the containers from communicating directly with the NAS Host IP. This creates a "silo" effect where Tailscale can reach the network but cannot manage the NAS itself.
IP Forwarding Reset: The setting, which is required for Tailscale Subnet Routing, is frequently reset or disabled by the OS after network configuration changes or reboots in the Beta version.net.ipv4.ip_forward=1
Both F2-221 and F5-221 upgraded to TOS7.0.0392 without any issues. Thanks!
F5-221 - TOS7.0.1298 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1298 - 2x3TB JBOD - 1x4TB Single USB
OK so far on F4-425 Plus and F4-223 but hibernation settings are turned back on after the update.
Also, when displaying processes, I really wish the screen would remember the sort order.
F4-424 Pro (x2) at 7.0.1298
issue with jellyfin - can not reach it anymore via the app center = the port is wrong / https://192.168.1.1xx:5443/jellyfin/ instead of http://192.168.1.1xx:8096/web/#/home.html
Generally trying to establish link modes on asymmetric lan ports will not work well. Either restrict the 2.5Gbe port to 1Gbe or just use the 2 ports separately. {e.g. I use the slower port for things like Network UPS communication or desktop}. This has been documented previously iirc.
F2-424 Updated.
Did this appear after the update? If possible, please provide a screenshot. We will try to check it.jdcesari wrote: ↑20 Jan 2026, 21:22 issue with jellyfin - can not reach it anymore via the app center = the port is wrong / https://192.168.1.1xx:5443/jellyfin/ instead of http://192.168.1.1xx:8096/web/#/home.html
yes
after last update
i can not make screenshot, because it is only a wrong url
after last update
No, this isn't a system update. This issue appeared in the latest Jellyfin update. In the app incorrectly specifies the port for Nginx. Instead of 8096, it specifies 8098.
F4-424 MAX TOS 7
