How to Resolve the Issue of F8 SSD Failing to Boot or Automatically Restarting After Installing a 3rd Party OS or TOS7
About TNAS hardware
tonzurakoite
Re: How to Resolve the Issue of F8 SSD Failing to Boot or Automatically Restarting After Installing a 3rd Party OS or TO
Post by tonzurakoite »
TMjack wrote: ↑09 Feb 2026, 16:04 Based on the information you provided, the PCIe HUB chip (ASM2806) used in the F8 SSD product is already the latest version. Previously, we received feedback from some users indicating that certain M.2 SSDs caused device crashes or automatic restarts due to their own quality issues. To accurately identify the problem, we recommend that you test each M.2 SSD individually to isolate the faulty one. Additionally, please provide the brand and model information of the related M.2 SSDs.
Disks 1 and 5 are both WD_BLACK SN850X HS 8TB drives and Disks 2, 3, 4, 6, 7 and 8 are WD_BLACK SN850X 8TB drives. I've swapped every single one out with a Corsair MP600 Pro NH 8TB drive and it still reboots randomly regardless/ all the drives tested okay. I waited a day after each swap and the F8 SSD Plus would randomly reboot with each swap still. What other options exist to stop the random reboots?
MikeZhang
Post by MikeZhang »
tonzurakoite wrote: ↑17 May 2026, 22:56
Sorry for the inconvenience, you may enable debug mode from TOS desktop dock bar "Support and Help", when random reboots happen for several times, please re enter TOS desktop to export debug logs and send to support email for analysis, you may attach this link to the email at the same time.
andrnils
Sweden
Post by andrnils »
Hello!
I'm have much the same trouble as everyelse here... I run FreeBSD, and as far as nvme it does not crash/restart even drives in all slots. Problem is I cant run that program to see the which version of firmware I have for the pcie-bridge.
I do however get sever instability issues with usb, which drops rather quickly when accessing disks/sending data.
I really need a fix for this general problem. Having a bios that almost 1 year old when so many people are running into problems? Are you working on a fix?
MikeZhang
Post by MikeZhang »
andrnils wrote: ↑15 Jun 2026, 02:01
Please generate system log TOS desktop dock bar "Support and Help" and send to support email for us to analyze issues with usb drops rather quickly when accessing disks/sending data
anuraj1
Post by anuraj1 »
I have successfully updated the BIOS, but when trying to check the firmware (FW) version of the motherboard PCIe expansion chip (ASM2806), I get the following output:
Asmedia PCIe Gen3 Switch SPI ROM Update Linux Utility - Version 1.7.4.0
Found 1 Asmedia PCIe Gen3 Switch Upstream Port
pcilib: sysfs_write: write failed: File too large
[04:00.0] PCIe Switch 0: 17 11 01 40 00 00
SpiIdle: timeout!!!
    SpiIdle: SPI Ctrl Register 0 = 0xFF
SpiIdle: timeout!!!
SpiIdle: timeout!!!
SpiIdle: timeout!!!
Since it does show that my version is 17 11 01 40 00 00, when I try to update it, I get this output:
ASM2218GetCustomerID: Null
Target[0] DID: 00002806
Update SPI flash ROM start:
PCIe Switch 0 : PCI bus 4, device 0, function 0 ...
SpiIdle: timeout!!!
SpiIdle: timeout!!!
SpiIdle: timeout!!!
SpiIdle: timeout!!!
    Can't detect SPI flash ROM!!!
PASS : 0        FAIL : 1
 == Please REBOOT to reload new firmware ==
Can anyone please help me figure out what is wrong?
Terramaster F8 SSD Plus
64GB RAM
8x4TB NVME
anuraj1 wrote: ↑31 Aug 2026, 10:06
Is your current system version TOS 7? In TOS 7, the kernel has been upgraded, so firmware can no longer be flashed using this method. Before upgrading the F8 SSD Plus, we recommend re-running the 6.0.794 update once more, as the update will automatically refresh the PCIe firmware.
anuraj1
Post by anuraj1 »
No, I'm running Unraid 7.
64GB RAM
8x4TB NVME
anuraj1 wrote: ↑31 Aug 2026, 17:31 No, I'm running Unraid 7.
This method only applies to TOS 6.
anuraj1
Post by anuraj1 »
Is there no way to update unless I'm on TOS6? The title of the thread is about 3rd party OSes.
64GB RAM
8x4TB NVME
anuraj1 wrote: ↑01 Sep 2026, 04:19
You can also update the firmware for the motherboard's PCIe expansion chip (ASM2806) in a standard Linux environment. I have sent you the firmware via a private message on the forum.
Return to “Hardware”
