TOS 6.0.500 Official Release
MrVanz
Italy
Re: TOS 6.0.500 Official Release
Post by MrVanz »
Where is the link to download the TOS 6.0.500 package? If I use online is stuck to 4% indefinitely
TerraMaster F4-424 Pro
TOS 7.0.1140
4x WD RED PRO 16Tb (TRAID - BTRFS)
1x WD Black SN770 1Tb (Hyper Cache)
UPS Power Walker VI CSW 1500VA 900W
MrVanz
Italy
Post by MrVanz »
Done smoothly, TerraMaster support said to me to Restart NAS and then online method goes fine
TOS 7.0.1140
ellowsmile
Post by ellowsmile »
lshollis2024 wrote: ↑20 Sep 2024, 00:22 I installed the update to 6.0.500 on my F4-423. While it fixed the date and time listing on the info page it broke Plex. It will not go to enabled. I reinstalled it and it still fails to enable.
Also it didn’t fix the UPS disconnect problem. Nice to have terminal access that seems to work fine.
Try giving folder permissions to the app. I had the same problem with Plex
F4-423
jpeckinp wrote: ↑19 Sep 2024, 11:55
You can try running the task again, and it will recognize the USB device you plugged in when you created the task.
Regardless of what model you are using, at this stage, only users who have participated in the TOS 6 beta test and have a TOS version of 6.0.460 or higher can update to 6.0.500. Only users who have participated in the TOS 6 beta test can use the 6.0.500 installation package. For all other users, please wait for our notification as updates will be rolled out gradually.
jpeckinp
Post by jpeckinp »
ellowsmile wrote: ↑20 Sep 2024, 01:20
Where are you granting these permissions? I can get access on my phone via LAN and over internet but my Fire Sticks wouldn't find the files. I uninstalled and reinstalled and it worked for a few hours now it's back to not allowing my Fire Stick.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
jpeckinp
Post by jpeckinp »
jpeckinp wrote: ↑20 Sep 2024, 11:15
I might have found out my issue. For some reason upnp gets turned off on all the updates. I enabled it and my Fire Sticks see my Plex files again. We shall see if that's the case.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
DCCentR
Post by DCCentR »
Can i use TOS6 installation package from F4-424 Max page for F4-424 Pro for clean installation?
F4-424 Pro
nale88
Bosnia & Herzegovina
Post by nale88 »
This is not because of the system update. I'm still on TOS5 (5.0.131 I believe - no updates since I bought it 4 months ago), and my Plex stopped working yesterday. All permissions are set, no issues.
I did update the Plex few days ago.
I had to delete the main Plex folder to have it running again.
F2-423 2x4TB
abs1ck
Post by abs1ck »
After restarting the emby server, the folder rights for the system user "emby" disappear every time
