TOS 6.0.500 Official Release
Target Users:
Users currently running TOS 6.0.420 Beta or later versions.
Note:Updates for other users will be released gradually. Please stay tuned for update notifications.
Warning!
  • This update is only applicable to TOS 6.0.420 and later versions. Do not update if you are using other versions of TOS.
  • After the update, it will not be possible to revert to an earlier version.
  • This version is not compatible with the Beta version's permissions, and user permissions will need to be reconfigured after the update.
Release Notes
Bug fixes:
1. Fixed some issues with Domain.
2. Fixed some issues with Sleep Mode.
3. Fixed some issues with User.
4. Fixed some issues with Network.
5. Fixed some issues with User Group.
6. Fixed some issues with Share Links.
7. Fixed some issues with File Service.
8. Fixed some issues with File Manager.
9. Fixed some issues with TOS Desktop.
10. Fixed some issues with Shared Folder.
11. Fixed some issues with OTP Two-Factor Authentication.
Enhancements:
1. Added Terminal functionality.
2. Added Debug Mode.
3. Optimized the restoration of file system snapshots.
4. Changed login authentication to a drag-and-drop method.
Important Information:
Update Procedure:
Other Software Downloads:
Download TNAS PC 5.2.003 for Windows OS:
https://download3.terra-master.com/Apps ... .2.003.exe
Download TNAS PC 5.1.202 for macOS (x86 and ARM architecture):
https://download3.terra-master.com/Apps ... .1.202.pkg
Download TNAS PC 5.1.202 for macOS (ARM architecture):
Download TNAS Mobile 3.2.47 for Android:
https://download2.terra-master.com/TNAS ... 3.2.47.apk
TNAS Mobile for iOS: Download from the iOS App Store.
danno10000
Re: TOS 6.0.500 Official Release
Post by danno10000 »
Thanks, updated successfully.
jpeckinp
Post by jpeckinp »
Is there a fix for external USB drives changing drive letters? I'm having issues with my backup drive changing letters and then USB Copy and TFM backup fail or put the data on a different drive.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
star
Sweden
Post by star »
updated succesfully
Failed to update = "Insufficient space".
2x500GB nvme in Traid > 400GB free BUT I also have 2 x 6GB hdd mounted as 'external' drives.
I suspect update package is looking to hdd for installation and not finding space there (obviously).
I have notified @pm by email
I will try removing the external drives and see if that changes anything.
Pedrosa48
Post by Pedrosa48 »
I am setting up my new F2-424 later today, could you please advise me what version will be downloaded during setup.
Pedrosa48 wrote: 19 Sep 2024, 17:00
Your model and TOS version are not on the update list, please wait!
Gremlin wrote: 19 Sep 2024, 16:51 I will try removing the external drives and see if that changes anything.
Nope, still not seeing space on Volume1 (>400GB). "Failed to update - insufficient space ......."
TMroy wrote: 19 Sep 2024, 17:05
F2-424 "not on update list" :?: :?: :?:
So this is only for new customers buying the VERY latest models.......
Try publishing the ONLY for these models list and saving your customers time and energy. (Despite everything I am really P******D OFF!)
Gremlin wrote: 19 Sep 2024, 17:33 F2-424 "not on update list" :?: :?: :?:
Other than the number of drive bays, what is the difference between F2-424, F4-424 and F6-424?
F6-424 has a TOS6.0.500 package available. (Therefore MUST be on the update list.)
The others do not!
