TOS 7.0.0559 Beta (X86) is Released for Update
rfbjr
Re: TOS 7.0.0559 Beta (X86) is Released for Update
Post by rfbjr »
I see duplicate notifications/emails for rsync jobs.These happen to be recurring ones, if that matters.
Also I happen to notice new notification options for various apps, under control panel/notifications. While all the new options are turned on by default for each, the email isn't. Just more of an FYI.
F6-424 & F4-425 Plus at 7.0.1341
F4-424 Pro (x2) at 7.0.1341
Nitrokalel
Mexico
Post by Nitrokalel »
todos mis dispositivos se actualizaron sin ningun problema, todo OK la aplicacion de virtual box sigue funcionando y la aplicacion de VMs tambien en otros dispositivos, exelente actualizacion cada vez menos errores felicidades.
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
Joesh
Indonesia
Post by Joesh »
rfbjr wrote: ↑28 Apr 2026, 21:39 My version of USBCopy is 2.1.170, is that the latest version? Maybe future posts could include what the version of x app should be?
The newest version is 2.1.184
BTW updates successfully on my F2-423
luismartin
Post by luismartin »
I have 12 disks in RAID 5 (200TB) and a couple of days ago I installed a 1TB M.2 as a balanced hypercache.
When I boot the enclosure, disk and hypercache activity reading and writing is frantic for almost 3 hours.
Is this a normal behavior how is working hypercache?
Naturally, I've disabled hypercache while awaiting your response.
rfbjr wrote: ↑29 Apr 2026, 18:54 The sync was triggered because the system won't fully come up during one of the reboots, I couldn't putty in and had no choice to force power off the unit.
As requested: TOS_SystemReport_20260429_064241.zip
(My Onedrive link)
https://1drv.ms/f/s!AgP4K-RskQ9MjLwJvJG ... Q?e=2GWq4N
Is this a system report related to issues with the PostgreSQL service and filemanager service?
Found PCIe correctable error record, unsure if it is related to the issue you encountered Does this problem occur by chance rather than always?
We will continue to check in order to discover something
rfbjr wrote: ↑29 Apr 2026, 22:14 I see duplicate notifications/emails for rsync jobs.These happen to be recurring ones, if that matters.
Recorded, will verify the issue.
luismartin wrote: ↑30 Apr 2026, 04:16 I have 12 disks in RAID 5 (200TB) and a couple of days ago I installed a 1TB M.2 as a balanced hypercache.
Based on the existing information, we are currently unable to guess the reason You can consider observing the DiskIO read and write status of processes and devices through the following commands on the terminal:
pidstat -d 3
iostat 3
rfbjr
Post by rfbjr »
I might do that on my f6 it has 6 x 8tb drives and after every boot the disks go busy for about an hour. It like the cache is comparing its data for each disk. IMO
(My Onedrive link)
Additionally, after restarting the NAS, will errors related to the FileManager service, PostgreSQL service, and PCIE (M.2) still occur?
Has the Correctible Error of PCIE (M.2) also occurred before?
How long does your F4-424 last?
rage
Post by rage »
After this last update, 2 of my 3 devices came back fine
The other one I see the following
Failed to retrieve data
502 Bad Gateway when running file manager
I seem to have large PostGres files
3.4G /etc/postgresql/13/main/base
3.5G /etc/postgresql/13/main
