TOS 7 Is Now Out of Beta — Official Release
EriChan
Re: TOS 7 Is Now Out of Beta — Official Release
Post by EriChan »
Flyingbike wrote: ↑15 Aug 2026, 15:44
Thank you so much for sharing such a detailed diagnosis and technical workaround!
We have forwarded your findings and suggestion regarding automatic Service Worker deregistration directly to our development team for review.
Thank you again for your valuable contribution to the community!
Warius
France
Post by Warius »
I own a F8 SSD running 6.0.794 TOS version. I'm a bit confused about what I'm supposed to do in order to install sucessfully TOS 7.0.0747. Could you please explain me the required steps?
My F8 SSD SSD is running fine on 6.0.794 TOS version and I absolutely want to avoid an update that will make it failing to boot properly or repeatedly restarting automatically. I'm not a tecnical expert and what is decribed here viewtopic.php?p=49723#p49723 really scares me... :shock:
Thanks in advance for your answer! :mrgreen:
EriChan
Post by EriChan »
That guide is only intended for units running older motherboard BIOS or PCIe bridge firmware. If your device already has the updated firmware, you do not need to perform those complex manual steps.
Since your F8 SSD is already running TOS 6.0.794, you already meet the base OS version requirement.
Recommended Steps:
1. Check Your BIOS Version via the Web UI (No terminal required):
  • Go to Control Panel > General Settings > System / Hardware Information.
  • If your BIOS version is MADN0301.V07 or higher, no manual BIOS flashing is needed.
2. Contact Support for Assistance (if needed):
If your BIOS version is lower than V07, or if you feel uncomfortable checking/upgrading firmware via the command line, you can contact our technical support team via the link below to assist you with a safe upgrade:https://salesiq.zohopublic.com/signatur ... 97d0be8892
3. Perform Manual Update to TOS 7:
  • Once verified, download the official TOS 7 update package.
  • Go to TOS > Control Panel > General Settings > System, choose manual update, and upload the package to proceed with the upgrade.
JEG
Austria
Post by JEG »
EriChan wrote: ↑17 Aug 2026, 18:35 That guide is only intended for units running older motherboard BIOS or PCIe bridge firmware. If your device already has the updated firmware, you do not need to perform those complex manual steps.
Recommended Steps:
My F6-424 (TOS 6.0.794) is on the list of applicable models, but i checked and the bio version is MADN0102.V05, which is lower than the one you mentioned (MADN0301.V07). So does that mean i have to perform those complex manual steps?
If it's not as simple as directly updating the firmware as before (I'm not tech-savvy), will i be missing important security features if i stay on TOS 6.0.794? I can't afford to lose access to my NAS :?
shotgun57
Post by shotgun57 »
RyanYang wrote: ↑23 Jun 2026, 10:52
Nice Job Terramaster!
I have two Terramaster F8 ssd units and three Terramaster D4-320 usb extensions.
After following your directions, both F8 ssd servers and all three usb D4-320 units are online with no errors!
I needed to update both F8 ssd bios and firmware, but that went very smooth.
After updating, the installation of TOS 7 was no problem.
Even the second update to 7.0.1130 went very smooth.
Thank you guys for posting all that information and how to get the job done correctly. :D
EriChan
Post by EriChan »
JEG wrote: ↑22 Aug 2026, 21:49
For the F6-424, you do not need to perform those complex prerequisite steps or BIOS updates. You can directly upgrade to TOS 7 by manually uploading the update package.
While we recommend upgrading to TOS 7 to experience the latest features and enhancements, staying on TOS 6.0.794 remains a safe and reliable choice, and you will not miss out on critical security features.
EriChan
Post by EriChan »
shotgun57 wrote: ↑23 Aug 2026, 08:55
Thank you so much for your positive feedback and recognition of TerraMaster!
astartes
Italy
Post by astartes »
f8 ssd here, as indicated by thread and support i update via gui to TOS 6.0.794 and next to 7. restarting never ends and stuck before login page.
with support i reset nas and start again, screen by screen. same problems.
so support ranted about usb flash procedure. it's a commercial nas, even doing the reset was going too far.
now iam going back one more times to 6, hoping it works and looking for an rma and having back my money to switch to a real commercial ready product
astartes wrote: ↑05 Sep 2026, 17:59
What do you mean by "stuck before login page"? Could you provide a screenshot and describe it in detail? Before upgrading to TOS 7, please confirm whether the current BIOS version and the PCIe expander chip firmware version are up to date.
astartes
Italy
Post by astartes »
For F8 SSD and F8 SSD Plus users: Before updating, first update the system to 6.0.794. The firmware will be updated during the system update
i have installed successfully 6.0.794
now i have bios madn0301.v02
now i have done a reset so can't show message, but was something like "loading in progress, wait"
