UncleJohnsBand wrote: 08 Aug 2024, 11:05
what is your previous version?
fcs001fcs
Post by fcs001fcs »
I am on TOS 6.0.436 Beta and noticed that in Docker Manager the CPU percent indication is zero for all my 10 containers listed. They should always read a slight % usage and, if the container is working hard, a much higher percentage.
It did work on prior TOS versions, and I think it worked on TOS 6.0.420, but I am not 100% sure on that.
I uninstalled Docker Engine and Docker Manager and the re-installed both apps after a NAS reboot, but I have the same problem.
Question to TM: Is this the issue that TM has stated before about other Apps that the Docker Manager App needs to be updated to work with the new TOS 4.0.436?
F4-423 - 2 x12TB & 1x14TB & 1x16TB - BTRFS TRAID
UncleJohnsBand
Post by UncleJohnsBand »
TMroy wrote: 09 Aug 2024, 00:09
6.0.420
Lex
Post by Lex »
I fix my problem.
In /etc/passwd not been user 'super1'
But in /etc/shadows it been.
I add user, and can login. But i delete all on system disk and reinstall system.
F4-423
Lex
Post by Lex »
And one more problem.
I run external apps, like GitBucket. But it write '(Access denied !) - you need to login on TOS with an admin role account'
I login as admin. Can I run this app, or need wait for update?
F4-423
Wait for app update
carlosdesedas
Panama
Post by carlosdesedas »
guys.. I think I found a bug on TOS 6.0.436 beta, coming also with the same problem from 5.1.145... please head to this forum post where I describe it.. it's regarding an APC UPS 750 being connected to the F4-424 Pro through USB to sense power outages and gracefully shut down..
viewtopic.php?p=37208#p37208
Lex wrote: 07 Aug 2024, 22:06 How reset password.
I update system. It request username and password. System cant send email. I push skip this. It request update page. I refresh page in browser. And i see login screen. But password not work.
Could you please describe your operational steps in detail?
You update system from which version to which version?
After update, the web page asked you to setup a new password and username to the superuser, right?
You did it, and you pressed button to send verification code, but it fails to send, right?
after that, you pressed "Skip" button, and then?
what did you mean 'It request update page'?
OneOfaKindDPC wrote: 08 Aug 2024, 23:29
From the screenshot you provided, it appears that you have set up a RAID 10 configuration. Please check if any disks have been detached from the array. You can view the hard disk list to see if all disks are recognized. Are the disks connected correctly? You can try disconnecting and then reconnecting the disks. Also, in the hard disk list, you can check if the health status of the disks is good.
fcs001fcs
Post by fcs001fcs »
I did some deleting and re-mounting of disks on my F4-423 (TOS 6.0.436) to do a fresh install of TOS and now the "Overview" for the "System Info" is using my 2nd NVME Disk (sdzb) as the temperature indication in the "Hardware" section of the "Overview" page.
I would like it back to the first HDD "sda".
Question to TM: How do I change settings or config file to move the temperature indication on the "Overview" page to the first HDD "sda"?
