TOS 7.0.0746 Official Release (X86) is Now Available
quella
Re: TOS 7.0.0746 Official Release (X86) is Now Available
Post by quella »
I have a F4-423 on v7.0.0765 of TOS with dual raid NVME disks for the system, Storage Pool #1. I also have dual 8TB HDDs as Storage Pool #2.
I just performed the upgrade from v6 to v7. I first removed the HDDs and followed the posts that walked me though the BIOS upgrade and tweaking of the disk order. All went well. I booked up the system and all appears good. When I go to disks, I see all my disks, but when I go to Storage Pools, I see that my HDD (Storage Pool #2) is showing an error saying "RAID is corrupt". It seems to think that the HDD disks are missing, yet I see them in the Disks menu.
Thoughts or ideas on how to get the Storage Pool back, if I can? Mount is greyed out. I have tried to also remove and plug back in the drives but that did not correct anything.
When I go to the two HDD disks and I hover over the greyed out Mount, it says, " Disk filesystem does not meet mounting requirements." This is showing on both of my HDDs. Not the NVMEs.
Not sure if this matters or not, but in v5 these two drive were system disks and in 6.0 they showed as being system disks along with the newly installed (for v6.0) system disks which are the NVMEs. I can see on the two 8TB drive that there is a small FAT partition as the first partition and the RAID the following partitions.
Phil
Post by Phil »
quella wrote: 30 Jun 2026, 23:48 I have a F4-423 on v7.0.0765 of TOS with dual raid NVME disks for the system, Storage Pool #1. I also have dual 8TB HDDs as Storage Pool #2.
Please contact us online directly through this link, and we will resolve this issue for you.
jpeckinp
Post by jpeckinp »
jpeckinp wrote: 25 Jun 2026, 07:18 Still having this issue trying to setup new backup using USB COPY app.
I setup the location to save the backup to and it just randomly picks one of my drives and then when it tries to backup it fails.
The destination on both of these backups should be the same but for some reason the first one(Jane Pictures)gives drive SDG and the actual drive name is SDF. The few times I've tried it the name has changed from SDE, SDI and SDG and all 3 are valid drives in my Drive bay.
The Plex Backup runs just fine but it was a backup that I had setup months ago and is going to SDF like it should.
Issue solved. My sister didn't tell me she emptied the folder and created a new one. So it failed trying to backup an empty folder.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
quella
Post by quella »
Having the issue with the Storage Pools after migrating from v6 to v7, can I simply delete the pools and Erase the two RAID drives and rebuild it? I do have a backup of the data I found, so not sure which is more time consuming, having Support assist in fixing it or just deleting myself and Erasing the drives and rebuild from scratch. Thanks.
Phil
Post by Phil »
quella wrote: 01 Jul 2026, 21:32 Having the issue with the Storage Pools after migrating from v6 to v7, can I simply delete the pools and Erase the two RAID drives and rebuild it? I do have a backup of the data I found, so not sure which is more time consuming, having Support assist in fixing it or just deleting myself and Erasing the drives and rebuild from scratch. Thanks.
If your data has been fully backed up, you can manually delete the storage pool and volume and then recreate them. However, you can also contact us directly for a faster service.
XFNeo
Post by XFNeo »
How to enable apps like docker engine\manager, openclaw on startup?
EriChan
Post by EriChan »
XFNeo wrote: 03 Jul 2026, 06:51
These apps should auto-start by default, but the current version has a known bug causing this issue. We’ve confirmed it and it will be fixed in an upcoming update. Thanks for your patience.
rob44
Afghanistan
Post by rob44 »
Following, i have the same issue.
EriChan
Post by EriChan »
rob44 wrote: 03 Jul 2026, 23:06
Thanks for the feedback! We’re already aware of this issue, and it’s on our list to be fixed in a future version. Please stay tuned for the future release.
JakeF150
Post by JakeF150 »
Success F2-425 from 6.0.794 direct to 7.0.0747 and updated to 7.0.0765.
USB Copy (all defined backups worked)
Plex (server worked)
Model: F2-425, Memory: 16gb, Drives: 2x12tb raid 1, Backup: 5tb usb, 4tb usb, Version: 7.0.0765
