TOS 6.0.500 Official Release
Re: TOS 6.0.500 Official Release - Samba/SMB
TMRyan wrote: ↑28 Sep 2024, 21:56 I don't quite understand, can I make an assumption? You have user "user1". After changing the workgroup to workgroup123, you cannot use "workgroup123\user1" to access TOS through SMB. Is this your problem?
Not quite.
As you can see The display name in Explorer does not match that set in TOS. Not the workgroup shown for NAS-1 is correct as set in TOS5.1.145.
I had not noticed any variation up until 6.0.500. I am currently working on the assumption that SMB does not actually enforce the mapping of 'workgroup' as I don't appear to have access uses. However this is a new installation and only working with minimal users with maximum permissions.
I am using smb3.
abs1ck
Post by abs1ck »
My NAS turned off again, all kinds of hdd sleep modes are turned off, there are no errors in the logs. Why do I even have one system disk now? Before the update to the release version, all 4 were system-based
abs1ck wrote: ↑29 Sep 2024, 01:47
Have you checked the partitioning on all your hdd. I suspect more than one is partitioned with required os partitions but just not active.
abs1ck
Post by abs1ck »
Gremlin wrote: ↑29 Sep 2024, 05:19
Yes, the partitions are the same, but previously all 4 HDDs were displayed as system
I understand that under 6.0.500 only max of 2 drives are assigned to system. I'm not sure what has happened in you case.
abs1ck
Post by abs1ck »
Gremlin wrote: ↑29 Sep 2024, 06:42
build *.500, in general, turned out to be the most interesting :D
All other beta versions were more stable))
adminsanek
Post by adminsanek »
Dear developers, how long do we have to wait for the fix for version 6.0.500? It is impossible to use the product, but the money has been paid for the product!
F2-423 TOS 6.0.507 16GB System Partition on 2 x 8TB Traid; SSD m.2 128 Gb
abs1ck
Post by abs1ck »
adminsanek wrote: ↑30 Sep 2024, 03:00
I was lucky in a sense, I already wanted to order a new F6-424 MAX, but then this bug appeared in the release version, which they have not been able to fix for the second week, this has become a great indicator of the attitude towards the client. Now I'm just wondering how much longer to wait for this dumpster to work, because it's just impossible to use it.
gergoke
Hungary
Post by gergoke »
I installed tomorrow morning the 6.0.507 update which is solved the file permission problem.
ColaChen
Post by ColaChen »
:) thanks!
gergoke wrote: ↑30 Sep 2024, 20:13
