[Help] CloudSync doesn't sync .dot files from Dropbox  [SOLVED]
Re: [Help] CloudSync doesn't sync .dot files from Dropbox
This issue has been resolved in CloudSync 4.0.039 for TOS7 Beta.
mmalchuk
Post by mmalchuk »
TMzethar wrote: ↑11 Jun 2026, 10:54 This issue has been resolved in CloudSync 4.0.039 for TOS7 Beta.
could you please fix this issue in the TOS6 Stable ?
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
mmalchuk wrote: ↑11 Jun 2026, 16:03
Sorry, this CloudSync app update is only available on TOS 7. We recommend checking here to see if your NAS is eligible for the upgrade:
viewtopic.php?t=10183
mmalchuk
Post by mmalchuk »
Upgrade to unstable TOS to check if the app updates work as expected. Kidding? Where is the support?
TOS 7 is officially out of beta. If you're still worried about stability, feel free to wait a bit before upgrading.
mmalchuk wrote: ↑21 Jul 2026, 17:11 Upgrade to unstable TOS to check if the app updates work as expected. Kidding? Where is the support?
Same place it's always been! For what we pay for support, you can't beat it for value. ;)
Frustrated Beta Tester!!!
mmalchuk
Post by mmalchuk »
TMzethar wrote: ↑21 Jul 2026, 17:48 TOS 7 is officially out of beta. If you're still worried about stability, feel free to wait a bit before upgrading.
Ok, how long we should wait before upgrading? :roll:
Gremlin wrote: ↑21 Jul 2026, 18:09 Same place it's always been! For what we pay for support, you can't beat it for value. ;)
I see, it's not a support it's just a forum :D
mmalchuk wrote: ↑22 Jul 2026, 04:46 Ok, how long we should wait before upgrading? :roll:
I'd suggest watching the release notes and feedback here. If something doesn't feel right, you can choose not to delay the upgrade if you prefer.
viewforum.php?f=28
Return to “CloudSync”
