TOS 7.0.0392 Beta (X86) is Released for Update
Re: TOS 7.0.0392 Beta (X86) is Released for Update
samius wrote: ↑21 Jan 2026, 04:09
jdcesari wrote: ↑21 Jan 2026, 00:52
The latest Jellyfin update is to avoid port conflicts with Emby. Additionally, after establishing a remote connection via the TNAS PC app, you can play Jellyfin videos smoothly when connecting through a virtual IP. :)
For such initial attempts at changes, we hope to hear more of your thoughts and feedback.
PeteBest
Post by PeteBest »
Sorry to disappoint,
The issue with completely stalling the device is not sorted.
Th attached situation happened after I tried to login through the TNAS app for Android.
There are about 40 TOSDemon tasks clogging the CPU & memory.
Pete
samius
Post by samius »
TMzethar wrote: ↑21 Jan 2026, 15:11
Everything's fine, the decision to install Jellyfin in Nginx is a good one. Сan also use the old port, whichever is more convenient. Need only recover right port (8096) so you don't lose access through Nginx.
F4-424 MAX TOS 7
mnewland
Post by mnewland »
@samius how do you find the port jellyfin is using after the update so you can use it again?
im using jellyfin installed through App Center
samius wrote: ↑22 Jan 2026, 00:22
My TNAS
  • Device = T6-423
  • RAM = 32gb official Terramaster ram
  • Disks = 3 x Seagate IronWolf ST400VN006 4TB
  • TOS = 7.0.1225
  • BIOS = 5.19
  • Mobile App = 3.5.0.81
NAS always run in Security Isolation Mode
samius
Post by samius »
I'm having a problem with the web server: "Forbidden. You don't have permission to access this resource."
I don't know which version this problem started with, but the web server worked fine in TOS 6.
F4-424 MAX TOS 7
samius
Post by samius »
mnewland wrote: ↑22 Jan 2026, 14:56
You can find port in control panel - services and process - port. 8096 - standart port for jellyfin. But now, shortcut from desktop and shortcut in top panel send to diferent places. One leads to Nginx, the other leads in the direction of the Jellyfin app itself.
F4-424 MAX TOS 7
PeteBest wrote: ↑21 Jan 2026, 21:17 The issue with completely stalling the device is not sorted.
Based on the information you provided in previous topics and here, it is likely a performance issue (F2-221). I notice that you have Jellyfin enabled, which is a resource-intensive application. Perhaps you could temporarily disable it and observe the load situation when using the TNAS mobile app.
Try adding RAM. Both my 221 models run 10GB total, but I don't run similar software.
{I used appropriate Crucial 8GB sticks - CT102464BF160B DDR3 1600 MHz CL11 Laptop Memory, Multicolor, 8 GB from Amazon - but they may not be available today - I didn't check.}
samius wrote: ↑22 Jan 2026, 18:32 I'm having a problem with the web server: "Forbidden. You don't have permission to access this resource."
Hi.
Regarding the issue you mentioned, you can try going to Control Panel - Application Settings to access the user permissions for WebServer. If the problem persists, we hope you can provide a screenshot to help us locate and troubleshoot the issue.
Aritoc
Sweden
Post by Aritoc »
Hello! I'm having problems updating from 7.0.0299. I'm getting the message "Update check failed. Please check your network connection and try again.". The NAS has an internet connection and everything else is working as intended.
