TOS 6.0.577 (X86) is Released for Update
Re: TOS 6.0.577 (X86) is Released for Update
Thank you! I always understood that TOS 6.x was not compatible with the 221 series (as they wrote in version 6.530, the only one that can be installed without the beta)... who knows if they will put a version that we can also install with the 221 series, I'm waiting for it with curiosity.Linuss wrote: ↑24 Dec 2024, 18:48Sorry, my bad. "the beta 6.0.229 and from that I then installed 6.500" not the 6.5, from 6.0.229 to 6.533, after that i had automatic updates and everything worked fine.
Beta 6.0.460 almost destroyed my NAS..
Updated the F4- 424 pro, no problem! if someone's ip is missing, then simply link this ip to the mac address of the NAS on the router in DHCP and it will always distribute the same ip to your device.
F4-424 Pro
F2-210
F2-210
Yes. Bizarre.
Frustrated Beta Tester!!!
Exciting !
Updating f4-424max now ...
And an ideal foil for those annoying relatives - "sorry, must get this fixed".
- skyrocket777
skyrocket777 wrote: ↑25 Dec 2024, 02:32I wonder if I should install the latest beta version TOS 6.0.530 (and then upgrade it automatically)
That is what I did on my two F2-221s. No problems at all.
Due to the inability of the interface used in the Docker Engine to retrieve image information from the Docker official image list (registry), the registry is currently unable to display the list of images. We are in the process of adapting to a new interface. In the meantime, you can temporarily use the terminal on the TOS desktop to pull images using commands. We will update the application as soon as possible to resolve this issue.
plex server on port 32400 does not work and the application is installed incorrectly, it is impossible to send to the desktop, when reinstalling it reaches 100% and writes "install" instead of "installed" version plex 1.40.2.8396
F4-424 Pro
F2-210
F2-210
