4 digit Verification code after 3 failed logins
Odbod
Re: 4 digit Verification code after 3 failed logins
Post by Odbod »
Absolutely the same problem. Not a helpful feature obviously not tested much. :evil:
After multiple failed login attempts, the IP will be locked for a period of time and you will not be able to log in successfully even if you enter the correct identification code.
Please wait for some time before retrying, or restart TNAS and try again.
Also, you need to make sure that the username and password are valid.
Odbod
Post by Odbod »
TMzethar wrote: 18 Sep 2024, 12:03 After multiple failed login attempts, the IP will be locked for a period of time and you will not be able to log in successfully even if you enter the correct identification code.
Did not get blocked/ locked out . The "correct" Code did not verify. eventually after like 10+ different codes all which I returned correctly, it accepted one.
So I immediately turned down the required level of nonsense of the required passwords to something I definitely will not forget or hopefully mess up consistently (without writing it down!). Then changed all the passwords to "password"...Not.
So far no more incorrectly decoded correct codes required!
Return to “Security”
