[Help] F4-423 TOS 6.0.794 - NAS running Syncronization after every shutdown and bootup.
Exarkun
Malaysia
Post by Exarkun »
I got the F4-423 a few months back.
Installed and updated all the way to TOS 6.0.794 and proceed to populate with 4 identical 12TB drives and did a TRaid. Initialised fine, sync and worked great for the following few months and enjoying using the NAS.
Last week I did a clean shutdown via TOS web interface and the NAS powered down normally. Next morning I powered it back on, booted fine and it was operational and everything was smooth. A few moments later started hearing the HDDs working hard. Went into TOS and saw the NAS started a Syncronization (Sync) task. So after about 36hours, sync ended without any errors and I continued using like normal. I assumed the NAS ran Sync because it had been months since I fully shut down the NAS, so I thought nothing of it.
Days later, I again shutdown the NAS fully via TOS web interface. Upon power up, the NAS again ran Sync on its own and had to wait for it to finish the task.
I got curious and again shut down the NAS after it COMPLETED the Sync. Boot up the NAS yesterday and it AGAIN ran a new Sync process.
What is going on? Does TOS6 run Sync after every shutdown and power up? Is this a known bug?
Note that I don't get the Sync task running if I run a 'Reboot' via TOS interface. This only happens after a full shutdown and power up via the front power up button.
F4-423 running TOS 6.0.794
Re: [Help] F4-423 TOS 6.0.794 - NAS running Syncronization after every shutdown and bootup.
The system typically resynchronizes when it detects an array anomaly.
Please generate and download the log report via TOS > Technical Support > Problem Reporting, and then send it to our technical support email address ([email protected]). We will analyze it.
Please include a link to this post in the body of the email.
Exarkun
Malaysia
Post by Exarkun »
CursaYang wrote: ↑20 Apr 2026, 15:58 The system typically resynchronizes when it detects an array anomaly.
I tried to send an email to [email protected] with the included zipped log reports generated by the NAS. However Gmail is blocking the zip file from being attached as it is flagged as potentially dangerous. Can I upload the zipped log reports here instead?
You can upload the system report to a cloud drive like OneDrive or Google Drive, and then share the link in the body of an email.
Exarkun
Malaysia
Post by Exarkun »
CursaYang wrote: ↑20 Apr 2026, 18:16 You can upload the system report to a cloud drive like OneDrive or Google Drive, and then share the link in the body of an email.
Ok, I have sent the email and link the report in Google Drive. Thank you.
