[Help] TOS7 cannot mount remote SMB folders.
Varlei
Brazil
Post by Varlei »
I connect to my server without problems using my Synology DSM 7.3.2 and Asustor ADM 5.1.2, but with Terramaster TOS7 I get the message "The source path is not available." They are on the same network and I'm using exactly the same credentials.
Any ideas?
FredMutter
France
Re: [Help] TOS7 cannot mount remote SMB folders.
Post by FredMutter »
I’m quite surprised that this feature hasn’t been improved in the new version. It was a bit of a mess with TOS 6 and it seems to still be a bit of a mess with TOS 7 :-(
In the meantime, I also use the Unix command ‘mount’ to do it myself.
FredMutter wrote: ↑15 Apr 2026, 12:12
Seems to work ok for me.
Frustrated Beta Tester!!!
Varlei wrote: ↑15 Apr 2026, 11:43
We have internally tested multiple machines with different system versions, and all can mount normally. The issue you're encountering may be related to the network environment or SMB settings. If convenient, you can find online customer service through the entry in the lower right corner of the official website to schedule a remote session, where our engineers can conduct troubleshooting.
FredMutter
France
unix mount and umount works
but mount using the external volume dialog not
here is screenshot
FredMutter wrote: ↑15 Apr 2026, 18:44 unix mount and umount works
here is screenshot
If the NAS can be mounted normally in the terminal, this indicates that the NAS connection is working properly, and there may be some issues on the front end. If it's convenient for you, you can schedule an engineer for remote troubleshooting.
FredMutter
France
CursaYang wrote: ↑16 Apr 2026, 17:24
here is screenshot
yes I will do that (in order to have a better software with TOS 7)
FredMutter wrote: ↑16 Apr 2026, 19:37
Did you get this sorted?
I'm curious because the subject of the thread was "TOS7 ....." yet the screen shots posted show the TOS6 interface? Or, was that updated later in TOS7 Beta release?
FredMutter
France
Gremlin wrote: ↑18 Apr 2026, 16:09
I do have an appointment for Monday
FredMutter
France
And I do have TOS 6 indeed.
But I suppose the problem remains with TOS 7. This is why I want to contact the hotline
Return to “Network”
