TOS 7.0.0517 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
1. If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
2. If you log in immediately after an update or restart, a brief error message may appear. This occurs because certain background services are still in the process of initializing. All core functions remain unaffected and can be used normally. This display anomaly will be addressed in a future release.
Here, we sincerely thank user @rfbjr, @nedhedrick, @DCCentR, @snapsh0t, @mnewland, @Gremlin, @Nitrokalel, @OttO1916, @joka388, @Metyrion, @bladi3990, @storageninja, @Joesh, @DBa, @apfelnico, @logicalx and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where the button on the login page might not highlight correctly.
2. Fixed an issue where the MSDFS VFS feature might not take effect.
3. Fixed an issue where a newly created volume might not display in File Manager under specific environments.
4. Fixed an issue where operating the application list in Backup Center might trigger an error message.
5. Fixed an issue where modifying a username would clear that user's application permissions.
6. Fixed an issue where clicking Remote Access without an internet connection would display a Failed to fetch data notification.
7. Optimized the loading performance and status display on certain pages.
8. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.520 for Windows OS.
2. Download TNAS PC 5.2.520 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.520 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
EgorA
Re: TOS 7.0.0517 Beta (X86) is Released for Update
Post by EgorA »
Updated ok, but cannot update Docker Manager
F4-423
storageninja
Netherlands
Post by storageninja »
Unable to update docker manager, could you guide me how to collect the right logs?
EgorA wrote: ↑14 Apr 2026, 17:05
storageninja wrote: ↑14 Apr 2026, 17:18
Thank you for your feedback. We have confirmed the update issue with Docker Manager, and our R&D team is currently working on a fix. Please wait for the new version to be released.
rfbjr
Post by rfbjr »
All three devices updated w/o issues. Testing later today
F4-424 Pro (x2) at 7.0.1298
Sorry, the previous download link is invalid. Please click refresh in the upper left corner of the App Center and try again.
EgorA
Post by EgorA »
CursaYang wrote: ↑14 Apr 2026, 18:21
Updated ok
F4-423
storageninja
Netherlands
RyanYang wrote: ↑14 Apr 2026, 19:20
Yeah works fine! New GUI is awesome, thanks for fixing this bug.
storageninja
Netherlands
Is TOS 7 GA now as this topic does not contain the "beta" word?
weerasak
Thailand
Post by weerasak »
Login mobile app update done.
