[Help] Brand new D4-320 won't power on
mimimi
Wales
Post by mimimi »
I bought this less than a month ago and it was working fine, had some formatting stuff to do with the drives inside before I used it so I powered it down and now it just won't turn on. I've tried removing USB, taking drives out, swapping the outlet and removing / reinserting power cable and it just does nothing. Is this a known issue? I'm aware it could be the power supply but I'm using the out of the box one that has less than 12 hours of use atp.
Re: [Help] Brand new D4-320 won't power on
Hi.
Please check if the LED on the original power adapter is lit.
If you have another power adapter with a 12V output (from a router, ultrabook, monitor, etc.), you can also try replacing the original one to test it.
sianderson
Post by sianderson »
this may be a really silly question, but you do know theres a power button on the back of the D4-320, it wont just power up by plugging the power cable in?
a rather strange place to put it in my opinion especially when its placed in a comms cabinet
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
MikeZhang
Post by MikeZhang »
sianderson wrote: ↑03 May 2026, 16:26
Yes it will auto power on once you plug power cable in, to avoid pressing by mistake
sianderson
MikeZhang wrote: ↑03 May 2026, 20:33
funny that mine didn't, i had to push the power button, so what is the functionality of the power button if plugging the cable in powers it up and unplugging it powers it down?
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
MikeZhang
Post by MikeZhang »
sianderson wrote: ↑04 May 2026, 03:58
Do not shut down the device by unplugging the power cord. This is an abnormal power outage and may cause file system errors or data loss. The power button is the device's main power switch; press the power button to turn off the device after the safety button has ejected.
sianderson
MikeZhang wrote: ↑04 May 2026, 10:53
but you cant get to the button as its hidden on the back of the unit
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
MikeZhang
Post by MikeZhang »
sianderson wrote: ↑04 May 2026, 20:37
You may consider D6-320 if you prefer it on the front?
Return to “USB Series”
